Hello All,
I am brand new to Triumph ownership (And to be honest, car maintenance as well) and am working on the Girling rear brakes of my TR3A. I could feel that the car was having a stuck brake or brakes so I got it onto jack stands and determined that the driver's side rear wheel was locked... The rear brake cylinder piston seemed to be jammed (I even saw a little bit of corrosion in the bore along the piston head). I assumed the cylinder was the problem.
I ordered a new drum, cylinder, brake adjuster, flexible hoses and shoes and springs (I had everything apart anyway). However the pistons in the new cylinders don't move freely as I thought they would by hand... I don't want to rebuild the entire system, just to find that I haven't addressed the actual problem.
Question is how freely should the pistons move in the wheel cylinder? Or can they only be accurately tested with hydraulic pressure applied?
I appreciate the patience with my elementary questions!
