TR6 New VTO15x6 in for the Triumph TR3-TR6
VTO has been out of the silver Classic 8 wheels for the big Triumphs for a few months now, well we got them in now, and for the first time we have the Classic 8 in the black center for the big Triumphs as well, and the new Retro 4 in both black and silver for TR3-6 as well. Give me shout if interested.
Hap Waldrop
Then of course the Classic 8 available in both black and silver
martx-5
DNK said:
Come on Hap, Wider!!!
A six inch rim will handle a 215 tyre...that's 8.5 inches of rubber on the road. That's a lot of tire for these cars. :driving:
I like the Classic 8's...too bad I'm committed to wires. Maybe I'll stuff longer wheel studs in the TR3 so I can swap wheels and rims around. :smile:
DNK
Art, Need it for the Wedge
7's and 8"s
Deleted member 11772
Hap,
How bout prices for the silver model 8?
THanks,
Stockybod
Hap Waldrop
Don, we have 15x7 in the new wheels as well I'm pretty sure we can drill to that size, may already have them drilled. The next production run we will do 16x7 and 16x8, probably be ready by next summer.
Denny, the 15x6s are 175.00 a wheel.
Stuart, here's a old pic from the Superlite wheel days, we used to be the Superlite US distributor, before we made our own wheels, VTO. Anyway this is the only big Triumph photo I have with the 15x6 +3mm offset, which is the same as the width and offset as VTO. As far as a photo of a big Triumph to have the Retro 4 on it, well since we only had that new wheels for like 3 days, we're still waiting on the first one, I do have some customers that have been waiting on this wheel I have emailed, so there should be a set/s of them out there real soon. I've got to get you Triumph guys to send me more pictures of your cars with VTO wheels on, and also need to get more feedback from Triumph owners as to what tire sizes they are using, the education always continues.
Also, we have 15x6 in both styles, and colors, pre-drilled in 4x3/4" for you Spit/GT6, TR7/8 guys, and for you same guys wanting to stay with 13" wheel, I got 13x5.5s on a smoking hot intro deal right now thru the end of the month, $450.00 a set, have them in both colors and both stlyes.
Darrell_Walker
Beautiful wheels, Hap. If I ever decide to swap out my wires, I know what I'm getting! Any thoughts about making spline-mount versions?
Hap Waldrop
We did spline wheels with the Superlite, in 14" and 15" the 15" offset was pegged towards the MGBs though, so it didn't work on the Triumphs. Here's the deal on spline drive wheels, the splined adapter cost as much the wheel to make, and it's heavy as all get out, nearly doubling the weight of the wheel, then MGB guys starting doing hub swap bolt on conversions (I did this to my MGB as well), and add to that 90% of the spline drive car owners want new shiny new spoke wheels instead of alloy spline drive wheels, and it made for really expensive, heavy wheel that nobody bought.
I have no idea what you Triumph guys have to do to swap to bolt on hubs, but if as easy as it for a tube axle MGB, then thats the way to go, it will cost much less and you get a light wheel.
Darrell_Walker
For TRs, it is pretty easy, they all used bolt-on adapters, so you just need to install longer studs. I hear you about the cost and weight, but they just look so cool....
martx-5
Darrell_Walker said:
For TRs, it is pretty easy, they all used bolt-on adapters, so you just need to install longer studs...
Actually, you have to install <span style="font-weight: bold">shorter studs</span> or cut off the ones you have, or the studs will stick out past the adaptors and foul the spokes. Another alternative is to use a 1/4" spacer between the hub and the wire wheel adaptor. That would be the way to go if you want to swap around between wires and alloys.
Edit: BTW, the studs in the rear of the TR3/4's are screwed into the hub and then peened over. A real pain in the butt to change.
Darrell_Walker
Going from bolt-on to wires you are right, I was talking about what it would take to go from wires to bolt-on.
martx-5
You are correct, my bad for not reading close enough. The discussion always seems to be going from steel wheels to wires, and I fell into that trap. :hammer:
Darrell_Walker
No worries. Good point about the older hubs with the threaded/peened stubs as well. Doesn't sound like any fun to change over!
C For Sale 69 Triumph TR6 Racecar Triumph Classifieds 0
J TR4/4A Vintage Triumph Register Build Codes Triumph 6
J SOLD!! Triumph TR 2 TR 3 windshield stanchion mounting plates Triumph Classifieds 3
oldbagpipe For Sale 1961-1962 Triumph TR4 Short Bubble Bonnet (hood) Triumph Classifieds 0
oldbagpipe For Sale '2' Triumph TR4 engines Triumph Classifieds 0
motzart007 Wanted In search of used seats for 1969 Triumph Spitfire MKIII Triumph Classifieds 0
C For Sale 1963 Triumph TR3b-TCF Triumph Classifieds 5
tr6nitjulius General TR 1/1/2024 in TRIUMPH Triumph 0
pbraun For Sale Triumph TR 250 Project Triumph Classifieds 0
R For Sale FS: Revolution 5 Spoke Wheels (Triumph) Other British Classifieds 4
S Spitfire Triumph Spitfire 1300 engine SU carb problem Triumph 10
tr6nitjulius TR6 TRIUMPH TR6 Triumph 7
tr6nitjulius General Tech TRfest 9/7-10th 2023 (150+ TRIUMPH Only) Triumph 6
R TR6 Triumph vin tag information Triumph 7
L For Sale British car collection for sale Morris Minors, Triumph Other British Classifieds 0
L For Sale 1961 Triumph Herald Saloon Triumph Classifieds 0
L My 1951 Triumph long ago British Motorbikes 0
tr6nitjulius TR6 TRIUMPH invades Redmond, Or for ATDI 2023 Triumph 4
Hamish Racing General TR At last a New Triumph Triumph 2
Got_All_4 General TR New Triumph Concept Car TR25 Triumph 14
tr6nitjulius General TR TRIUMPH TR6 the possibilities! Triumph 12
Got_All_4 TR6 Triumph TR6 PDWA Brake Question Triumph 1
XJtom General TR Triumph items of interest Triumph 2
B TR6 Triumph tr6 coolant leak Triumph 4
Gatheringtree TR2/3/3A Billet Pedal Cover Set w/ Triumph logo Triumph 0
D For Sale 1974 triumph spitty davidschab60@gmail.com Triumph Classifieds 0
Gliderman8 General TR Triumph emblem? Triumph 13
D TR2/3/3A Drive your Triumph day photo Triumph 6
AngliaGT General TR You Might Need Snow Tires for This - Drive Your Triumph Day 2023 Triumph 5
F For Sale Four Steel Wheels Triumph TR3 or TR4 Triumph Classifieds 5
J For Sale Triumph TR2 or TR3 elbow trim Triumph Classifieds 0
J For Sale Triumph TR3 door, left, for sale Triumph Classifieds 0
S TR2/3/3A Triumph TR3 Tail Light Issue when Headlights and Brakes are On Triumph 15
D For Sale Triumph GT6 for sale (possibly one of the worlds finest examples) Triumph Classifieds 2
S For Sale Triumph TR 2-3 Front Left Fender Triumph Classifieds 2
KVH General Tech Making the Triumph Engine Dolly Triumph 4
P Post-War Other Triumph Herald Engine ID Triumph 2
P Spitfire 1979 Triumph Spitfire starts then runs rough Triumph 2
J TR4/4A 1964 Triumph TR4 - Not Starting/Running Triumph 3
tr6nitjulius General TR All TRIUMPH Only Drive In 2022 Triumph 4
D Forum for Triumph TR6 only FORUM Navigation Questions 2
Quackedo TR6 1969 Triumph TR6 Differences Triumph 18
J Wanted WTB Triumph TR3 inner sills Triumph Classifieds 8
J For Sale Triumph Tr2/3 seat foams Triumph Classifieds 1
J TR2/3/3A TRIUMPH Radio? Triumph 13
J For Sale Triumph TR2, TR3, TR4 CAM SHAFT FOR SALE Triumph Classifieds 0
O Stag Triumph V8 Triumph 5
