Chris Willis
Just purchased a 59 100-6 good 10 ft car . Looks like show car from 10 ft . Well driven and pretty much well maintained . 108,000 miles .NO RUST. .... I would like it to drive better . Front end and a little steering play .
I see shims at end of steering column in manual . If I take this apart and remove shims with this improve " tightness" of steering .
also camber is too much . How to adjust?
This motor might b a little tired but plan to drive it as is .110 compression
I adjusted carbs and timing and found points really really gaped.
starts better and runs better now . I just eyed the gap . I find it's .015 was twice that or more. Will check with feeler gauge .
Could wide points make car run warm . As well as hard to start ? I guess if they were too wide would not start at all.
I've noticed it was running 190 and now just under 180 Temp
Any body know where to get parts for turn signal behind horn parts /repair
Thot I d never have one of these , especially the current prices.
Thanks for any advice .
