ScottFromNH
Hi everyone.
Like the subject says I am new to the forum and also new to owning a 1973 spitfire 1500.
The car I own was sitting in a shed for the last 10 years. After I got it home I noticed the clutch peddle wasn't working. when you pushed on it, it went right to the floor with no resistance.
However I worked on getting the engine running as I wanted to make sure the engine wasn't blown. I got the engine up and running pretty well since it has sat so long. However now for some reason the clutch peddle is so hard you can not even push it to the floor at all.
Any idea's of what happened or where I should start looking? I was going to try and drain the hydraulic fluid for the clutch and replace it with new fluid but not sure if that will even help right now.
More information on the car is that it is not drive able just the engine runs right now.
any help would be great.
