Matthew E. Herd
I have 165/70R13 Michelin X Radials on stock wheels. They fit just fine, so I'm sure that they'd work for you too. As an aside, Yokohama A032R's wear pretty well, and could be feasible for a limited use vehicle for street use. Much better handling, but they're about $110/each and might require a spacer on stock wheels. The smallest size (what I'm using), 175/60R13 is slightly smaller than my 165/70's in diameter, but it's marginal. They might also require a panhard rod for hard cornering. While this isn't difficult, it is one more thing to work on.
The Yokohamas should get you at least 6000 street miles (maybe more on such a light car). However, the nature of modern offerings for these cars don't include Falken Azenis, or anything else remotely sporty. Therefore, they can be expected to be 40-80k mile tires. Obviously the mileage doesn't really compare, but they're likely to dry rot before they wear out. However, the Yoko's will probably wear out first, but I'd imagine they'd still last a few years, depending on use.
Hi Guest!
