This concerns the 1971 MGB...
OK... the front suspension is done as far as I can tell with cleaning, painting, new bushings, new bolts, and torqued down. Only question is the outer A-arm bolt/nut where it attaches to the lower part of the swivel axel. Someone told me 28 ft/lbs of torque but the nut is well past the cotter pin hole...doen't seem correct. Should I back it out so the pin is in the castellated nut and just go with it being a little loose?
Rear suspension...My U-bolts are loose and one lower bracket that supports the rear shock arm is bent. I'm replacing all U-bolts, spring pads, and the bracket. I have jack stands under the rear axle. How do I support the spring so that I can loosen/remove the U-bolts and replace pads and bracket? Should I support the spring somewhere with a floor jack or what?
As always, ANY suggestions will be greatly appreciated. Thanks
Gary
ps. I'm really hoping to do this job tomorrow (Sunday) !!
Gary
Hi Guest!
