Just finishing the restoration of my differential. Started to install the pinion seal, and found that there is no way on earth it will fit. I bought it from TRF. The car is a solid-axle TR4A.
The seal's OD is 2.690 inches, and the opening at the front of the differential, where it has to fit, is 2.620. The old, original seal that I removed was 2.625 OD, which makes sense. I can't see any way this new one will go in, but maybe there is. If so, could someone enlighten me? What have you guys used?
I did a little research, and found that the seal no. 470487N is the one listed everywhere for the TR4, and I also found the dimensions in a Timken catalog (below). The TRF seal has those dimensions. It appears that the 451857 should fit; it's nitrile instead of polyacrylate, and there are small differences in the style of the seal. I don't think those differences are significant, so lacking any other suggestions, I think I'll get one of those.
