    Thanks and welcome to BCF!
New Member!!!
WJKB-TR6
Hi All, In 1993 I towed this 1973 Triumph TR6 home. It sadly sat rusting away until 2010 when I retired and decided to restore it with my limited skill and knowledge of British cars. Today all body work has been completed, a new coat of paint, and new soft top; interior needs lot of work. My goal now is to work on getting the engine to run smoothly. It is, however, road worthy. I will be reaching out for your assistance with your years of experience and knowledge. Regards, WJKB-TR6
Hi WJKB-TR6 and welcome to the British Car Forum. You will find plenty of friendly help with your TR6 whenever you need it. Post your questions in the "Triumph" section of the forum anytime you need help.
Your car looks great.... I also have a '73 TR6. I noticed that you have the bumper overriders; I didn't think they were introduced until 1974?
Hi Gliderman8, Thanks for the Welcome note. I will be adding Posts in the "Triumph" section (appreciate this!) once I get the hang of how things work here. Yes, mine do have the bumpers and it was manufactured late May 1973. I am not certain, but think it was manufactured with the bumpers so they could be sold in US starting Year January 1974????? Need to check history on that. I surely have questions on how to make my engine purr like a kitten.
I have a question (If inappropriate at this time, please let me know.). I have difficulty starting in the mornings to the point of wearing down my battery. If I prime both CD175 Strombergs with a squirt of gas, it will start up right away with half choke on. I just installed a new fuel pump. Any ideas? Thanks again! WJKB-TR6
Try posting the question in the Triumph section as you will get a greater response.
There could be multiple issues to check:
Fuel flow... clogged lines, crud in gas tank, clogged fuel filter.
Floats may be sticking, carbs may need rebuilding, diaphragms could have deteriorated.
These are just my initial best guesses.
Head over to the Triumph section for additional answers.
I had them on my 73 GT6.
Hello WJKB-TR6
Welcome to the forum.
Great looking TR6 and I love the background in your photo.
The Triumph section is very active so you are sure to get plenty of tips and help for your TR6 questions.
The pub is an area where almost anything comes up for discussion.
David
Thanks for the information. I will followup on all.
Hello WJKB-TR6
David
Thank you for the Welcome! Am finding my way into this web site and appreciate your help.
Welcome! What's with the WJKB in your user name?
Are you from Detroit?
I'd start off checking the float level in both carbs. They are set up such that fuel rises almost to the top of the jet at static conditions.
That makes it easy to pull fuel into the engine.
If set low, you need a whole lot of vacuum, just to lift the fuel.
You get the full vacuum applied to that jet when running. Not so much at cold start.
Thanks, I will add this to my list. I am considering having the rebuilt, any recommendations? Will TR6-75 work on a TR6-73 without modifications?
I'd stay with the original carbs. All I associate with the newer carbs is increased complexity, decreased emissions and decreased engine output.
Rebuilding is easy. Just take the tops off the carbs and replace the rubber diaphragms.
The 4 screws that you remove on top of each carb appear to be Phillips but are actually Pozidrive. Do yourself a favor and get a set of Pozidrive bits before you strip your screw heads.
Resetting the float requires removing the carbs and flipping them over. Remove the phillips screws, measure the floats and bend a small piece of brass with needle nose to adjust.
I've only had to adjust the floats one set of carbs. They don't go "out of adjustment" on their own. I assume because a previous owner, over the past 40 years, got inside and played with things. That car was hard to start until I did.
This is the guy I buy most of my parts from. You need two of the first part ZEMS577A
http://trf.zeni.net/TR6-TR250GB/index.php?menu=A&page=117
