New Healey Owner
Mickey Richaud
Well, half-owner - friend and I went in together and acquired a BJ8, '64/'65 vintage. Not sure what exactly we're going to do regarding bringing it back to life; depends on what we find as we dive into it.
Picture makes it look pretty good, and all things considered it does appear to be, once we cleaned all the grime from it. Looks like it has been through at least one repaint - current color seems too orange to be Healey (Colorado?) red. There is rust to deal with - only serious structural issue is the condition of the two radius arm boxes. Otherwise, there's some rust to repair on the floors and trunk. Fuel tank is toast, interior is pretty much non-existent, top frame is fine, except for its wooden parts, etc., etc. Body is sound; some light bondo here and there, and a few dimples to be dealt with. Chrome is excellent, all gauges, switches and wiring is present, though wiring will most likely need replacing.
We're going to start tearing into it tomorrow and see if we can start it. It's been sitting since '03, but our understanding is that the motor was rebuilt not long before then. Of course, brake and clutch hydraulics will be rebuilt. After we get it running and stopping safely, we'll determine where to go from there. I really wish I had room/finances/SWMBO's permission (;)) to keep it myself, but probably not in the cards.
Anyway, I look forward to chatting with you folks for info/advice/sympathy in the coming months as we explore this beast.
Best,
Mickey
This side shot appears to show good body panel alignment, not often found on a car with this, uh, 'provenance.' Colorado Red is orangeish, but not usually this much; have you acquired the BMIHT cert?
Good luck and have fun!
Mickey Richaud
Mickey Richaud
Hey, Bob - thanks! No BMIHT yet.
Jerry
Does it have the arm rest that opens? If so, I am just finishing an early BJ8 so if you need pictures, let me know.
Mickey Richaud
Mickey Richaud
Not much in the way of interior at all, so I don't know if it had it or not. Will get back to you if so - thanks!
Mickey Richaud
Mickey Richaud
Thanks, Reid - good to know!
Am I seeing possible collusion here ;)
Note my BJ8 was originally Colorado Red, but was repainted in a bronze metal-flake, then to a GM color called 'Peking Red*' which appears to be a good approximation for Colorado.
* Why are there so many 'chinese' reds (i.e. for the fan shield, etc.)?
Mickey Richaud
Mickey Richaud
Got into it a bit yesterday: pulled the door face plates/sill covers, and inner sills and rockers look good - a bit rusty, but quite solid. Also, radius arm boxes look better than we thought, but the rear floor panels will need replacing. Evidence points to Colorado Red as original color, though the hood has some BRG paint under the red, so it must have been replaced at some point.
Jerry - it does have a console arm rest - didn't see it initially. But it's going to need some work, along with all the other soft interior bits.
Jim found a set of seats, upholstered in blue vinyl with white piping, a white top, wood for the top frame and a steering wheel (rough, but better than what we have), exhaust down pipes, and a black tonneau cover - all for under $300!
Gonna try to get it started next week...
Mickey Richaud
Mickey Richaud
BJ8Healeys
I have the chassis number, and it's an early Phase 2, not a Phase 1 with the cubby box on the center console. (Note also the push-button door handles.)
Reid, how is it that you have the chassis number, and I don't? The exterior features of the car show it to be an early Phase 2, so it would not have the cubbybox console originally. Of course, some people have installed them in Phase 2 cars. And do we know that the chassis number it claims is really the one it left the factory with? lnquiring minds (especially those who have seen a lot of mis-identified BJ8s) would like to know!
Editor_Reid
Platinum
The owner - Mickey Richaud - is a fellow British Car Forum moderator and he contacted me privately and supplied the chassis number. Send him a PM to introduce yourself and/or direct him to the Registry webpage here.
Mickey Richaud
Mickey Richaud
Update: We've had a couple of delays before being able to get into it a bit. But here's what we've found thus far:
We were able to spin the starter over, after pulling it and cleaning up the brushes and armature contacts. Didn't measure pressure, but did get oil topside, so that's promising. Did a compression check and results were pretty disappointing - #2 cylinder was at zero, others ranged from 15-120. Found that #2 exhaust valve is stuck open. Pulled the head (Boy, is that dude heavy!), and were able to pop the valve back closed, though its action is very stiff. Pushrods all in good shape. Will be sending the head to the machine shop for a refresh.
Cylinders and piston tops look good. We figure the rings are probably stuck, so we filled the cylinders with Marvel Mystery Oil and will let that do its magic and see what develops there. We're hopeful that the bottom end is in good shape, but we shall see.
The only other thing to report is that the transmission oil is very clean; shifts through all positions easily.
Overall, we're still pleased with our find. Jury's still out as to how far we'll be going with this...
N Please help --- New owner of a 1958 Austin Healey Sprite Spridgets 4
J For Sale 1 owner 1959 Austin healey 3000 BT7 Austin Healey Classifieds 0
P new Healey owner Austin Healey 18
C Tacho drive - more help require for a novice Healey owner. Austin Healey 2
cmc140 Original owner search for 1956 Austin-Healey Austin Healey 20
BigGreen To be or not to be a Healey owner Austin Healey 4
P New Healey Owner ... What to expect? Austin Healey 17
JamesWilson New Jensen Healey Owner Other British Cars 21
saabmp3 New Austin Healey owner Austin Healey 7
Basil Healey 3000 Driver Handbook to some lucky owner! Austin Healey 0
J New healey 100 owner start up Q'S . Valve train Austin Healey 6
G New Healey Owner - BT7 Transmission Question Austin Healey 3
R For Sale 1960 Healey BN7 Oil Pan For Sale Austin Healey Classifieds 0
S Healey Will Not Start (a.k.a. "Failure to proceed") Austin Healey 3
dougie Jack & Bill Rawles attending The Healey World Challenge Road America September 13-15 Austin Healey 2
Editor_Reid New Edition of "Austin-Healey Quarterly" Available Austin Healey 1
giwplay1 Everything you need to know before purchasing an Austin Healey Austin Healey 15
Editor_Reid Healey 100 Frame Diagram Austin Healey 1
dougie Healey Hardtop on BAT Austin Healey 8
dougie Austin Healey 4000 Austin Healey 3
Patrick67BJ8 Healey Mechanic Needed - El Paso, Texas Area Austin Healey 0
T Healey In An Ice Cube Austin Healey 6
dougie VSCDA Healey World Challenge Road America Austin Healey 0
dougie Healey World Challenge 2024 Road America Racing 0
R Healey 100 Dipstick Stuck Austin Healey 12
L For Sale Austin Healey Parts!!! Austin Healey Classifieds 0
tahoe healey Healey Video Austin Healey 0
W Nash Healey Austin Healey 5
S Wanted WTB: 3.5 ratio diff/pumkin for '67 BJ8 Healey 3000 Austin Healey Classifieds 0
dougie Celebration of Austin Healey Double Event September 2024 Austin Healey 2
E For Sale Austin Healey 100 and 3000 parts Austin Healey Classifieds 1
nevets Letting the Healey go... Austin Healey 4
dougie Healey Racing Road America Fall 2024 Austin Healey 1
R Big Healey 100 Head Austin Healey 4
PAUL161 Photo: What Model of Healey? Austin Healey 7
E Wanted 1963 Healey 300 mark 2 front grille wanted Austin Healey Classifieds 0
Guido36 Webers on a Healey 100 Austin Healey 6
E For Sale Driver quality 1963 Healey 3000 mark 2 Austin Healey Classifieds 1
Editor_Reid Summer Edition of "Austin-Healey Quarterly" Austin Healey 4
dougie Healey Racing Austin Healey 13
P Wanted Wanted: Healey 100-4 frame Austin Healey Classifieds 4
red57 Alternative Healey Austin Healey 2
Dandare Healey Website Links Austin Healey 4
John Turney An Important Healey Up For Sale Austin Healey 1
M For Sale Austin Healey 100-4 Lemans Kit OEM Austin Healey Classifieds 5
V Opinions on 1953 Austin-Healey Austin Healey 26
dougie Did Big Healey Drivers Go Soft? Austin Healey 8
C What to do with my late father's Healey 100 Austin Healey 5
Martinld123 Steering Wheel Alignment [Lost centering on steering box 1956 Austin Healey, BN2] Austin Healey 14
B Healey Won't Start - No Spark Austin Healey 38
