TR2/3/3A new guy here....replacing floor TR3
shaunetr3
Howdy all,
I am here to find any tips on replacing the floor pans in a friends 1959 TR3.....don't know a thing about the car other than the fron 2 floor pans need replacing.
I have done a search and have determined the car will be on it's wheels and one floor pan at a time will be removed.
I will try some sort of bolt on brace from the windscreen mount to the rear somewhere and remove the door.
The rockers are in good shape as someone else has replaced them couple years back so there should still be strenght with one side of the pans cut out.
Any other pointers ??
martx-5
It is definetly best to replace one floor pan at a time to keep some structural rigidity. It is also best to span the door opening with some angle iron or something in order to keep the door gaps from changing.I bridged across from upper front valance to the rear just after where the dogleg panel goes down. This was done on the interior side. Of course, I have the instrument panel out, so you may have to bridge the gap lower down. I did this on both sides and then welded in a center brace between the two door opening braces. This can be use to lift the body off the chassis if need be.
You now have to make a decision on how you want to replace the floor. If you cut the old one out and want to replace it as originally fitted, I would say you almost have to raise the body some. I may be wrong about that, but having done this job, (original style replacement), I really don't see how it could be done without getting the body at least a couple of inches off the frame.
The other method I have seen is to cut out the old floor pan leaving about an inch of original pan around the circumference...except, of course where the removable part of the trans tunnel is. Then you trim the new panel to plop down inside and weld it up. Even then, cutting the old pan out, you have to be careful as the frame is underneath.
Palmer
It's been a long time, but I don't remember doing anything special when I replaced the driver's side floor on my 3. I'm pretty sure that I replaced the panel while the body was still on the frame, and I think that I did brace the door opening, although I don't think there was much pressure on the brace. I completely cut out the old panel, and ground away the spot welded flanges. Everything fit together pretty easily, and the door closes just fine. The floor does have a bit of "oil can" flex to it, though.
I think that if you're careful and methodical, the job is really pretty simple
Brosky
I can't help you with the floor, but welcome to the forum.
S
shaunetr3
Well after surveying what I have gotten myself into I thnk I can handle this.
I will run a couple braces across the top just for insurance, I'm sure it won't need it considering there is almost no floor on the driver's side.
Another question.......
Should i weld all the way along the seams or drill holes in the flanges and make like spotwelds ??
Banjo
Spot welds would be sufficent, as long as they're close togeather (i.e. every couple of inches) not only 3 or 4 per side. Then use a good automotive seam sealer.
On the TR3 the pans are not directly structural but they do affect the cars regidity and panal alignment, so the braceing is a good idea. Better yet if you can get the pans tacked in place, then test fit the doors to make sure everything ok. then finish welding the pans in place.
Good luck Guv'na
C New Guy here, Just got killer news Austin Healey 18
M New guy here Triumph 13
M Hello, new guy here with some questions. MG 6
69MGC Wanted Anyone know this guy? MG Classifieds 2
J New Guy 948 ribcase question Spridgets 6
S General TR New Guy, interested in Triumph Triumph 5
J TR2/3/3A Joe the TR3 Guy getting started with suspension Triumph 4
J TR2/3/3A TR3 Guy '59 project Basic body work finished Triumph 5
M TR4/4A Body guy needed. Triumph 0
HealeyRick TR2/3/3A Maybe I'll Rethink being a Healey Guy Triumph 8
Jer an Latest from a fellow LBC guy - new non LBC purchase to share Spridgets 11
HealeyRick 86 Year-old Healey Guy Austin Healey 13
anarchy99 New Guy with a sprite... Sorta Spridgets 172
MisterB MGB New Guy- Looking at Early MGB-Odd one MG 5
69sprite This guy has skills and building a beast of beauty Spridgets 6
bigbadbluetr6 General TR Who is the Triumph guy? Triumph 10
N New guy with a Bugeye Spridgets 56
W My drive line guy.... Spridgets 8
W This guy is going to be disappointed... Spridgets 23
B New Guy needs to know... Triumph 19
HealeyRick Guy Recovers Stolen Healey - 40 Yrs Later! Austin Healey 12
M Triumph guy needs Austin Healey part information Austin Healey 7
Frankenhealey The fat guy in the red suit was early this year! Austin Healey 20
N New guy, old project, and a brake problem Austin Healey 12
SilentUnicorn MGC I like this guy...69 MGC MG 4
Sopwith_Camel mg guy moving up Jaguar 31
J New guy from Oz Triumph 16
tri_carb_healey looking for a british car guy in miami MG 5
B Bill M - Standup Guy Spridgets 5
T You know you are a lucky guy when.... Triumph 49
M MGB-GT New guy from California with a GT [pics] MG 13
T old guy string vs. zip ties Spridgets 8
S A guy can dream, can't he??! Other British Cars 6
A New Guy! . . with Polarity issue Triumph 3
N I'm the new guy - I guess this is the Healey site Austin Healey 4
scoutll This guy has a high opinion of his car Spridgets 8
T Just so you guy know the MGC hasn't thrown me off Triumph 8
alfstr7 New guy with a carpet question Spridgets 12
Basil Met a local guy with an EType Jaguar 7
Steve69 New guy, new owner Triumph 9
M Spitfire AHBE guy looking at Spit Triumph 9
PAUL161 Is This Guy Crazy or Not ??? Austin Healey 26
healeyboz any idea as to where a guy could get this set-up Spridgets 11
ArkleyOkie New Guy Spridgets 16
scoutll Old guy, but new to the forum... Spridgets 60
T Once more for the stupid guy? Triumph 12
tahoe healey fuel pump repair guy Austin Healey 5
tony barnhill What a Guy Ray [mccalebr] Is!! Spridgets 3
John Moore "Bugeye Guy" Spridgets 6
roofman New classic mini guy coming next week British Motor Corp 9
