TR2/3/3A New engine mounts not sitting flat
Wow what an education on frame construction. Glad you figured it out; sounds like the shop worked with you and that can be difficult sometimes— good news.
Steve
This will put your mind at ease as you go forward knowing that this should not cause a problem down the road. You are correct if it doesn't fit something needs to be corrected. Frank
