Marvin Gruber
More than likely one or two valves were open and moisture got inside engine letting those two cylinder walls rust. Engine should run. Rings will wear quicker and engine will use more oil. Rings may be stuck in pistons as well, again more oil usage. Try it for a while, won't hurt. You might be lucky and engine will do just fine.
