Need seats & steering wheel MKII Sprite/MKI Midget
tony barnhill
Great Pumpkin - R.I.P
Just to make sure I still have it (Pretty sure I do), send me a PM...they'll come FEDEX Ground.
RickB
RickB
I just added a message to the PM thread we already had going.
Thank you, I'm sure I'll be able to make something good out of them!
RickB
RickB
What are the seat bottom dimensions? Anyone know?
Can someone measure for me the width, depth & thickness?
I'm looking into foam replacement that doesn't cost over $200 per seat.
(yes, I've just been over to Moss & VB - WOW!!)
nomad
The bottom pan fits exactly inside the seat base rails. Probably make up something similiar to whats there till you can get some pans. The cushions are fine as is. Get some contact cement and similiar foam then trim a piece to glue into any spots that need it. The seat foams are most important for making these seats comfy. To bad you don't have the seat pans.
KA
nomad
Bug-Eye seat pans are very similiar so any seat pan from 58 thru 65 will work. I'm sure you can find some fixable one's out there. Covers will be the big expense. You will need some pictures to see how the covers are attached and a bunch of the clips used for that.
KA
Billm
Or you can do as many of us have and just make a pan out of 1/2" plywood.
Cheap, effective and invisible.
Bill
RickB
RickB
KA
I guess I'll have to learn some more new things...
BillM - I'll be leaning on you (again) for information on this.
Here's a good question:
Today I found out the stock steering wheel is 16 inches diameter.
How do you guys slide in under that???
This is important because the one Ray sent me today is that one and I really want to use it but I'm going to need to find out how.
Maybe the stock seats are (or could be) really close to the floor?
B TR2/3/3A I need a definitive answer about 57 seats vs 59 seats Triumph 3
P TR2/3/3A Need Help Identifying These Seats Triumph 6
R TR2/3/3A TR3 Seats - Need advice Triumph 9
B MGB Anyone need some MGB seats or top frame [free]? MG 2
rkep01 Need stock Bugeye seats Spridgets 10
RickB Need info about Miata seats in Spridget Spridgets 49
J Spitfire Need early Spitfire seats Triumph 1
T E-Type seats - need some advice Jaguar 6
giwplay1 Everything you need to know before purchasing an Austin Healey Austin Healey 15
S Wanted Need an HVDA conversion kit for 73 TR6 Triumph Classifieds 3
K TR2/3/3A Does this fitting need a Whitworth wrench? Triumph 10
angelfj1 TR5/TR250 TR250 Need Help identifying wires (2 - black) feeding starting solenoid Triumph 6
Gliderman8 TR6 Now I really know why I need new shocks Triumph 11
Got_All_4 TR6 Need 1969 TR6 Expert Got Questions Triumph 17
W Need advice on installing new side curtain glass Spridgets 1
AngliaGT General TR You Might Need Snow Tires for This - Drive Your Triumph Day 2023 Triumph 5
M Wanted Need 59 Bugeye Dashboard. LHD. Spridgets Classified 1
Basil Admn Note Our neighbors need emergency help Triumph 0
Basil Our neighbors need emergency help Spridgets 0
Basil Admin Note Our neighbors need emergency help MG 0
K TR6 Need help with Mimosa Yellow Paint Triumph 1
T Storing nuts and bolts (so you can find what you need) Austin Healey 7
AngliaGT Need Ideas on Selling Our Midget Spridgets 10
tj_tr3_tr6 Wanted Wanted / Need / TR4 Engine Block for 62 Tim from So California Triumph Classifieds 3
drooartz MGB OD question - need to warm up? MG 8
H Wanted Need Spare tire rod BJ8 Austin Healey Classifieds 1
J TR2/3/3A Need help with a value for this TR3 please Triumph 6
M Need help removing the pinion assembly from a late 1275 steering rack Spridgets 7
shadowfever Wanted Need a Sprite Mk II bonnet Spridgets Classified 1
jackq Wanted Need a C Tach MG Classifieds 2
TheRealDestrux MGB 1977 MG MGB need help putting top down MG 1
apbos New/Old wheels for my Speedwell Sprite. Need Center Caps Spridgets 13
tr6web TR6 Quit running after a few minutes - need advice Triumph 15
AngliaGT I Need to Resist - 1980 Ford Fiesta Other Cars 9
vette Need BugEye Generator Austin Healey 7
vette Need BugEye Generator Spridgets 4
Got_All_4 TR6 Distributor Gear Mounting Question Need End Float Washer Triumph 4
J TR2/3/3A Need help with pivot and body bracket for hood Triumph 2
Madflyer For Sale Triumph GT 6 parting out need something Triumph Classifieds 10
KiwiStagguy Re building my power steering 71 Stag . Rust and pitting bad . Need a business name to fix it Triumph Classifieds 0
tinman58 TR2/3/3A Need super charger!! Triumph 7
B Wanted I need a small section of a bugeye bonnet Spridgets Classified 5
volunteer Wanted Need Door Seals, Vent Window Seals and Trunk Seal for Daimler ds420 Limo Jaguar Classifieds 23
Got_All_4 TR5/TR250 Need guidance for replacing steering column bushings Triumph 11
John Turney Need a Better Demister? Austin Healey 5
K TR2/3/3A Need advice on what my TR3A might be worth..... Triumph 10
69MGC MGC Need one MGB/C Splined Hub MG 1
69MGC Wanted Need one MGB/C Splined Hub MG Classifieds 4
Gliderman8 General TR Need clarification on Triumph Competition Preparation Manual TR250 TR5 TR6 Triumph 4
S TR6 Need wisdom on tr6 brake calipers Triumph 6
