Need Oval-head chromium-plated screws for "Mk IV"
ming11
Need chromium-plated slotted oval-head machine screws and cup washers for floorboard in luggage compartment of 1948 Jaguar 3.5 Liter saloon. No one anywhere seems to have them.
Wow, cup washers, blast from the past.
The last time I went looking for cup washers was when I was restoring a Robert Morton theatre organ console in 1997. You're probably running into the same problem I did: everybody who says they have cup washers actually just has finishing washers.
After a huge search, the only place which turned up was Schneider Pipe Organs. He kept some on hand for restorations, & had a vendor do a run of them from time to time.
If you can find no other source, contact Art Schneider at Schneider Pipe Organs:
https://www.schneiderpipeorgans.com/
He had brass & some nickel-plate (which looks like chrome).
The black anodized screws holding the center section of late Spitfires & GT6's to the car also originally had black anodized cup washers behind them, although it seems most have lost them & are suffering finish cracks as a result now, or they've been replaced by less-attractive finishing washers.
All I've ever found have been finishing washers. I finally settled for 'em, Doorman #745-004 (for #6 machine screws). They were the least 'obnoxious' of all I looked at. But I'm not aimed at concours.
It's just a concave washer that fits exactly in a countersink.
A finishing washer sits on top of a surface.
Re: Need Oval-head chromium-plated screws for "Mk
Roto, it must be this?
Trim shops will be able to supply you. You can try BAS of any other supplier in the USA. I know that Woolies in the UK has them.
Cheers, David.
Yes, that's a cup washer.
And that's an oval-head screw, too!
It seems like only in the last couple of decades that some suppliers have started calling finishing washers cup washers. Probably to attract buyers looking for cup washers who can't find them & decide to capitulate & just buy finishing washers.
ok I get it now: The cup washer is like a finishing washer but without the rounded outside edge. My car is full of the cup washers and I had not noticed because the "cup" washers disappear under the screw, leaving just an "edge" around the screw head!
I think you could take a flat thin washer and press it down to make the "cup" shape between male and female dies, (to make your own). The screws are still available in polished stainless steel.
Here's a lot of 150 #4 screws and 150 #4 Finishing Washers for $35.00 + shipping. Note: those are NOT Cup washers but the seller calls them cup washers. talking about that.
I thought of buying them but I don't need them.
https://cgi.ebay.com/ebaymotors/Jaguar-12...emZ330111619087
Good luck!
I have #6 cup washers in stainless, are you looking for #6.
Also a variety of oval slot machine screws also in stainless.
Dave.
We used 6-32 stainless Phillips oval head machine screws into "inserts". Marson. ...and check the Doorman number I posted above. This is the screw/washer and an insert:
With an old Jag I'd go with slot-heads. All available. These were for our '64 MGB. All we did was buff/polish the stainless heads to a bright shine.
Dr.: have you noticed how the backgrounds in both your picture and mine are similar? weird...
has anyone noticed how ming11 completely dissapeared from this thread? I guess we took it over...maybe he already found them while we were racking our heads and taking pictures!
regardless, for me it's been a learning experience. Cup Washers, Finishing Washers, slot and phillips screws, stainless and chrome.
Talking about chrome: anybody heard of Black Chrome?
do you know what it is? or are we talking "powder coating"?
I need to do the two "torque beams" in the engine compartment of my XJ-6, they are two solid steel bars forming a "V" from the firewall to each fender/wing;
they came painted black gloss from the factory, now the steel is rusting and paint is falling off. I need a permanent coating not to mention sandblasting them. but chrome is too shiny, needs to be black, No POR-15 or powder coat for me. Jet-Hot Coating was too expensive for my taste. Any other alternatives?? (see the attached file if you would).
Ex
My "background" was the underside of a synthetic fender cover, chosen because it looked close to yours. /bcforum/images/%%GRAEMLIN_URL%%/wink.gif
P'raps ming11 just likes to watch? /bcforum/images/%%GRAEMLIN_URL%%/devilgrin.gif /bcforum/images/%%GRAEMLIN_URL%%/jester.gif
The braces you want to refinish: sandblast them, coat 'em with epoxy primer and follow with gloss black. That should last a good LOOONG time. When/if it does need re-do, just clean, sand slightly and recoat. It's only a couple'a nuts/bolts to R&R after all.
Hi Exotex has found what you are looking for. I would suggest that the the screws be sourced as stainless steel items. When their heads are polished they shine like chrome, do not tarnish and do not shed their Finish like chrome plated screws under the stress of tools.--Fwiw--Keoke
Stainless is nicer than Chrome, if and when it rusts, you just use a fine sandpaper to polish off the rust, try THAT with chrome. But better still than Stainless Steel, I prefer Nickel. I had old electric guitars from the 1950's where they used Nickel hardware instead of chrome hardware, and nickel parts have a beautiful patina unmatched by stainless. Nickel does not rust, it only tarnishes to a dark gray, easy to polish to a beautiful silver tone.
<span style="color: #FF0000">I just made a discovery that might cause a stampede:</span>
<span style="color: #3366FF">Ford uses cup washers too!</span> I have a '92 Ford Aerostar minivan that has cup washers in all the upholstery panels and plastic upholstery fittings. Only problem is: They are not Chrome but Black Annonized or something like that, and the screws are, you guessed it, Phillips, and worse, it's hard to remove the cup washer from the phillips screw. I've been trying all day but it looks like the cup washer goes IN, but not OUT. Well if you can remove them let me know how. Once out they can be chromed.
