Need help adjusting valves
"Self-sufficiency"!!!
I need to do mine immediately after I get the toyota going again. This thread is yet one more reason not to open the manual. /ubbthreads/images/graemlins/thumbsup.gif
*CHICKEN!*
goes good with turkey and ham on rye. /ubbthreads/images/graemlins/jester.gif
To make it easier to see when a given valve is "completely open" place a box end wrench off of the jam nut for the adjusting screw so that it points away from the rocker, then watch the end of the wrench. When the rocker moves a few thousanths up or down, the wrench will move by a 16th of an inch. Very accurate.
Cheers
Hello Vping,
it doesn't matter if the open valve is at 99% the opposing valve, i.e. the one you are adjusting will be on the heel of the cam. It is certainly safer to do one valve at a time unless the manufacturer specify otherwise. (Triumph for instance with the TR5\6 range you adjust two valves at a time but there are also two valves fully open so the rule of 9 {13 for a six} still holds good.)
A handy way, if you do a lot of maintenance, is to buy a remote starter switch which you clip on to the solenoid and lets you crank the engine on it's starter motor, not precise enough for points but it is fine for tappets. I have installed a permanent under bonnet starter switch on my Triumph, simple to do and not expensive and oh so handy.
Alec
I am going to have to figure something out for next time. I have most of the parts from the fan forward off the car and I can easily get my hands & wrench in there. I will look into the remote switch and see what I come up with.
[ QUOTE ]
Cheers
[/ QUOTE ]
This is a really useful tip. /ubbthreads/images/graemlins/yesnod.gif
I've used a dial indicator in the past but setting it up for each valve was a bit crazy-making.... /ubbthreads/images/graemlins/crazy.gif
