NEED ELVA WHEELS
Michael Oritt
Well as long as Dale is looking I may as well give it a try as well:
I'm looking for one or more magnesium wheels that will fit my 1958 Courier. The wheels that I currently have are the Elva magnesiums, 15 x 4.5 with a 4 x 4" bolt circle. The studs are 3/8" and the wheels are not countersunk for usual lug nuts--I use aircraft locknuts but nylocks will work just as well. I have no spare and will buy one or four if available.
Best--Michael Oritt, Courier 100/15-L
Michael Oritt
Michael Oritt
[ QUOTE ]
Has the house settled??
[/ QUOTE ]
We move into a rental house in Solomons tomorrow, then I go to AHCA Conclave in Akron on Sunday, then I return and we settle on June 28. Then, assuming the engine goes back together as planned I get to run the Elva at BeaverRun and PVGP.
I don't have a spare so I had better not get a flat during the races!
Exciting times--Michael
Deleted member 3577
Most people have switched to the MGA rear end because of the well known Spridget problems.
I still have the original rear end and like it after all the upgrades.
Still....It has the 4" bolt circle rather than the 4 1/4" circle that the MGA has.
This guy makes magnesium Elva wheels. https://www.leechapmanracing.com/wheel.htm
(The 4" ones where not available last year..Let me know if you call him, he said he would do a run of the ones you want)
BTW.....A guy running a red Elva last year at PVGP said he wanted to sell a set......
I gave him my #, but he never got back to me.
Michael Oritt
Michael Oritt
[ QUOTE ]
[/ QUOTE ]
Dave--
I spoke with Lee Chapman a few months back and he said the same thing. Michael Clifford, at whose shop my car now is located, took one of my wheels over to Chapman's and the upshot of the conversation seems to be that he is not making any for a while. I have exchanged some email with Roger Dunbar in the UK (Elva Racing) and he seems to say that he can help me--I need to give him further details about wheel offsets, etc. etc.
If that guy ever calls you and you want to split a set or send him on to me please let me know--I have no spare and if I get a flat (or worse) I am outa gas.
I'm signed up for both Beaver Run and PVGP--Clifford is optimistic that the car will be together on time. I sure hope so.
Best--Michael Oritt
Deleted member 3577
Do you have your old wheels?
What I did for originality was take the centers out of the old rims & have 5" rims welded to the centers.
The old Elva disk wheels have 12 rivets holding the centers to the rim, so it is easy to remove. (3 per 90 degrees)
Then I sent them to this place https://www.stocktonwheel.com/wheel_widening.htm
( 5" rims, 5" backspace & they have the stock centers)
You can even put the original hubcaps on and make it a "sleeper"
I'll see if I can find the guy I talked to last year about the rims.
He said he wanted $ 1,500.00 for all 4 ( a great deal but too rich for me right now)
Michael Oritt
Michael Oritt
Dave--
I'm looking for one or more of the Elva cast magnesium wheels to match the four that I have on the car.
See photo attached for details--dunno if the letters are legible but it says E-L-V-A on the spokes.
Deleted member 3577
Yep.....Those are the ones.
You say they are 4 1/2" (not 5") X 15" with a 4x4" bolt circle.
What is the backspacing.....I'm guessing 4 1/2"
Michael Oritt
Michael Oritt
[ QUOTE ]
You say they are 4 1/2" (not 5") X 15" with a 4x4" bolt circle. What is the backspacing.....I'm guessing 4 1/2"
[/ QUOTE ]
Dave--
I'll have to wait to confirm the offset/backspacing--car is in NY and I am in MD. This, plus the wheel thickness, is what Dunbar wants to know. Meanwhile if you have a line on that fellow selling the wheels I would appreciate knowing.
Best--Michael
tr6web TR6 Need advice removing downpipe nuts Triumph 4
giwplay1 Everything you need to know before purchasing an Austin Healey Austin Healey 15
S Wanted Need an HVDA conversion kit for 73 TR6 Triumph Classifieds 3
K TR2/3/3A Does this fitting need a Whitworth wrench? Triumph 10
Gliderman8 TR6 Now I really know why I need new shocks Triumph 11
Got_All_4 TR6 Need 1969 TR6 Expert Got Questions Triumph 17
W Need advice on installing new side curtain glass Spridgets 1
AngliaGT General TR You Might Need Snow Tires for This - Drive Your Triumph Day 2023 Triumph 5
Basil Admn Note Our neighbors need emergency help Triumph 0
Basil Our neighbors need emergency help Spridgets 0
Basil Admin Note Our neighbors need emergency help MG 0
K TR6 Need help with Mimosa Yellow Paint Triumph 1
T Storing nuts and bolts (so you can find what you need) Austin Healey 7
AngliaGT Need Ideas on Selling Our Midget Spridgets 10
tj_tr3_tr6 Wanted Wanted / Need / TR4 Engine Block for 62 Tim from So California Triumph Classifieds 3
drooartz MGB OD question - need to warm up? MG 8
H Wanted Need Spare tire rod BJ8 Austin Healey Classifieds 1
J TR2/3/3A Need help with a value for this TR3 please Triumph 6
shadowfever Wanted Need a Sprite Mk II bonnet Spridgets Classified 1
jackq Wanted Need a C Tach MG Classifieds 2
TheRealDestrux MGB 1977 MG MGB need help putting top down MG 1
apbos New/Old wheels for my Speedwell Sprite. Need Center Caps Spridgets 13
tr6web TR6 Quit running after a few minutes - need advice Triumph 15
AngliaGT I Need to Resist - 1980 Ford Fiesta Other Cars 9
vette Need BugEye Generator Austin Healey 7
vette Need BugEye Generator Spridgets 4
Got_All_4 TR6 Distributor Gear Mounting Question Need End Float Washer Triumph 4
Madflyer For Sale Triumph GT 6 parting out need something Triumph Classifieds 10
KiwiStagguy Re building my power steering 71 Stag . Rust and pitting bad . Need a business name to fix it Triumph Classifieds 0
tinman58 TR2/3/3A Need super charger!! Triumph 7
B Wanted I need a small section of a bugeye bonnet Spridgets Classified 5
volunteer Wanted Need Door Seals, Vent Window Seals and Trunk Seal for Daimler ds420 Limo Jaguar Classifieds 23
Got_All_4 TR5/TR250 Need guidance for replacing steering column bushings Triumph 11
John Turney Need a Better Demister? Austin Healey 5
K TR2/3/3A Need advice on what my TR3A might be worth..... Triumph 10
69MGC MGC Need one MGB/C Splined Hub MG 1
69MGC Wanted Need one MGB/C Splined Hub MG Classifieds 4
Gliderman8 General TR Need clarification on Triumph Competition Preparation Manual TR250 TR5 TR6 Triumph 4
S TR6 Need wisdom on tr6 brake calipers Triumph 6
J MGB Need help identifying these parts MG 6
S TR2/3/3A Need New Battery for TR3A Triumph 9
B MGB-GT Need help with MGB GT rattle MG 0
AngliaGT MGB Need a GT [or Three]? MG 1
T Need an Anti-Tramp Bar? Austin Healey 6
K TR2/3/3A Help! No start! Need input from you guys. Triumph 9
T Wedge TR7 engine, need help identifying part. Triumph 5
