TR6 need a plug for my late model tr6 head
tr6lover
anyone know what size thread for a plug to go into where the egr used to be? this is for a 74 tr6 head, thanks guys! apparently hardware stores no longer carry hardware......or auto parts stores either.......go figure
Randy
YYCDave
From my PO who did the same thing, this from an old post of his "... the EGR port in the cyl head takes a 3/4-UNF thread (so it's not a pipe thread). I used a set screw of that size. That's one of those screws/bolts which has no shouldered head but rather a recessed Allen wrench fitting. Makes for a cleaner looking install. I had no trouble getting this set screw from a local fastener shop (look up fasteners in the yellow pages, and bring the EGR valve jam nut along if possible to positively match the thread). I was able to install it on my car so that the top of the set screw is flush with the cyl head surface..."
As stated it's absolutely flush with the block, as though it came from the factory that way! Not a great picture, but you can see the result above the rear carb here.
T
tr6lover
dave, i have had no luck in finding a plug for my head, if you could find one could i buy one off of you? thanks
Randy
Brosky
Randy,
I got mine here in RI at Lowes hardware section in the fastener isle.
EDIT: Not a set screw, but it works fine.
T
Tinster
Brosky said:
Randy,
<span style="color: #000099">Aw Paul, tell me it isn't so!!
Even without any auto mechanical skills or knowledge,
I know better that use any fasteners from Lowes or
Home Despot.
What were you thinking!!!
dale </span>
Brosky
Dale,
It's a brass plug, not a fastener that holds anything together and after a lot of miles it's just fine.
T
Tinster
Brosky said:
Dale,
<span style="color: #990000">If you purchased it at Lowes, how do you know for sure it is
really brass? It could well be plaster of paris painted to look like brass.
d</span>
Brosky
Randy, I think that's it. I took the EGR with me and matched it up.
Dale, the plumbing and hardware sections aren't too bad at Lowes. I'd never by grade 8 bolts for my driveshaft there, but for a brass plug, it's OK.
They also have a nice selection of fender washers and clips that can come in handy from time to time.
T
Tinster
I buy their masonry screws to hang paintings,
that's about it. Oh, they have a decent selection of ornamental bricks.
d
T Need a frost plug Spridgets 2
J General Tech I Need a Set of Plug Wires! Help! Triumph 14
Bruce_B Need Information on plug/screw size Spridgets 3
T Plug wires 101 - need help MG 6
tr6web TR6 Need advice removing downpipe nuts Triumph 4
giwplay1 Everything you need to know before purchasing an Austin Healey Austin Healey 15
S Wanted Need an HVDA conversion kit for 73 TR6 Triumph Classifieds 3
K TR2/3/3A Does this fitting need a Whitworth wrench? Triumph 10
Gliderman8 TR6 Now I really know why I need new shocks Triumph 11
Got_All_4 TR6 Need 1969 TR6 Expert Got Questions Triumph 17
W Need advice on installing new side curtain glass Spridgets 1
AngliaGT General TR You Might Need Snow Tires for This - Drive Your Triumph Day 2023 Triumph 5
Basil Admn Note Our neighbors need emergency help Triumph 0
Basil Our neighbors need emergency help Spridgets 0
Basil Admin Note Our neighbors need emergency help MG 0
K TR6 Need help with Mimosa Yellow Paint Triumph 1
T Storing nuts and bolts (so you can find what you need) Austin Healey 7
AngliaGT Need Ideas on Selling Our Midget Spridgets 10
tj_tr3_tr6 Wanted Wanted / Need / TR4 Engine Block for 62 Tim from So California Triumph Classifieds 3
drooartz MGB OD question - need to warm up? MG 8
H Wanted Need Spare tire rod BJ8 Austin Healey Classifieds 1
J TR2/3/3A Need help with a value for this TR3 please Triumph 6
shadowfever Wanted Need a Sprite Mk II bonnet Spridgets Classified 1
jackq Wanted Need a C Tach MG Classifieds 2
TheRealDestrux MGB 1977 MG MGB need help putting top down MG 1
apbos New/Old wheels for my Speedwell Sprite. Need Center Caps Spridgets 13
tr6web TR6 Quit running after a few minutes - need advice Triumph 15
AngliaGT I Need to Resist - 1980 Ford Fiesta Other Cars 9
vette Need BugEye Generator Austin Healey 7
vette Need BugEye Generator Spridgets 4
Got_All_4 TR6 Distributor Gear Mounting Question Need End Float Washer Triumph 4
Madflyer For Sale Triumph GT 6 parting out need something Triumph Classifieds 10
KiwiStagguy Re building my power steering 71 Stag . Rust and pitting bad . Need a business name to fix it Triumph Classifieds 0
tinman58 TR2/3/3A Need super charger!! Triumph 7
B Wanted I need a small section of a bugeye bonnet Spridgets Classified 5
volunteer Wanted Need Door Seals, Vent Window Seals and Trunk Seal for Daimler ds420 Limo Jaguar Classifieds 23
Got_All_4 TR5/TR250 Need guidance for replacing steering column bushings Triumph 11
John Turney Need a Better Demister? Austin Healey 5
K TR2/3/3A Need advice on what my TR3A might be worth..... Triumph 10
69MGC MGC Need one MGB/C Splined Hub MG 1
69MGC Wanted Need one MGB/C Splined Hub MG Classifieds 4
Gliderman8 General TR Need clarification on Triumph Competition Preparation Manual TR250 TR5 TR6 Triumph 4
S TR6 Need wisdom on tr6 brake calipers Triumph 6
J MGB Need help identifying these parts MG 6
S TR2/3/3A Need New Battery for TR3A Triumph 9
B MGB-GT Need help with MGB GT rattle MG 0
