Need a Pic of HS4's
Bud i believe the correct manifold will have the water pipes on it. i would post a pic of my unmounted set, if you can convince me to go out to the garage in my jammies and take one....its below zero here now and to be honest it is gonna take lots of convincing....
here is a pic i found on the web https://www.boicey.com/midget/pics/midget_overdrive_day_six_2.jpg
mark
G
Hi - I have some detailed "before" pictures of my 76 Midget 1500 engine compartment that may help you. I have tried to add them to this post but I have the hardest time trying to add pictures on this forum. I don't know what Basil did but I can never seem to get any photos loaded here. Email me at TBIRDRESTR@aol.com and I will email you the pictures.
Tony
Morris
Have you seen this:
https://www.quantumechanics.com/categories.php?op=newindex&catid=5
Scroll down the page and you will see a listing for a used euro-spec set for the 1500. Pretty affordable, too, IMHO.
The picture is small, but I think I can see where the water pipe runs through the manifold. If not, you could allways flare a piece of copper tube and strap it to the manifold (or wherever you want).
Thor
I've got some close up pictures of the alterations I had to do to the passenger foot well to make the dual hs-4 fit. Wasn't too bad although i wished I knew how to weld but since I didn't I just used epoxy.
Here is the link:
https://www.visn2.com/Flash%20Website/Carbs_for_1500.html
I found the dual carbs at quadmechanics which was mentioned earlier in this string. They were in good shape but i rebuilt them anyways. I love the look and performance I got. Good luck on the project.
Got_All_4 TR2/3/3A Need Pic of a Post TS60000 Occasional seat Please Triumph 5
J Need pic of BN4 Convertible Top Clamp Austin Healey 4
britndablood Need a pic of the trans tunnel front extention Austin Healey 3
K TR2/3/3A Need Pic & Dimensions of TR3 Spring Compressor Triumph 2
vping Throttle linkage - I need a pic MG 13
jlaird Need a pic or two Spridgets 5
H Sandblasted heat shield pic, need opinions MG 6
tr6web TR6 Need advice removing downpipe nuts Triumph 4
giwplay1 Everything you need to know before purchasing an Austin Healey Austin Healey 15
S Wanted Need an HVDA conversion kit for 73 TR6 Triumph Classifieds 3
K TR2/3/3A Does this fitting need a Whitworth wrench? Triumph 10
Gliderman8 TR6 Now I really know why I need new shocks Triumph 11
Got_All_4 TR6 Need 1969 TR6 Expert Got Questions Triumph 17
W Need advice on installing new side curtain glass Spridgets 1
AngliaGT General TR You Might Need Snow Tires for This - Drive Your Triumph Day 2023 Triumph 5
Basil Admn Note Our neighbors need emergency help Triumph 0
Basil Our neighbors need emergency help Spridgets 0
Basil Admin Note Our neighbors need emergency help MG 0
K TR6 Need help with Mimosa Yellow Paint Triumph 1
T Storing nuts and bolts (so you can find what you need) Austin Healey 7
AngliaGT Need Ideas on Selling Our Midget Spridgets 10
tj_tr3_tr6 Wanted Wanted / Need / TR4 Engine Block for 62 Tim from So California Triumph Classifieds 3
drooartz MGB OD question - need to warm up? MG 8
H Wanted Need Spare tire rod BJ8 Austin Healey Classifieds 1
J TR2/3/3A Need help with a value for this TR3 please Triumph 6
shadowfever Wanted Need a Sprite Mk II bonnet Spridgets Classified 1
jackq Wanted Need a C Tach MG Classifieds 2
TheRealDestrux MGB 1977 MG MGB need help putting top down MG 1
apbos New/Old wheels for my Speedwell Sprite. Need Center Caps Spridgets 13
tr6web TR6 Quit running after a few minutes - need advice Triumph 15
AngliaGT I Need to Resist - 1980 Ford Fiesta Other Cars 9
vette Need BugEye Generator Austin Healey 7
vette Need BugEye Generator Spridgets 4
Got_All_4 TR6 Distributor Gear Mounting Question Need End Float Washer Triumph 4
Madflyer For Sale Triumph GT 6 parting out need something Triumph Classifieds 10
KiwiStagguy Re building my power steering 71 Stag . Rust and pitting bad . Need a business name to fix it Triumph Classifieds 0
tinman58 TR2/3/3A Need super charger!! Triumph 7
B Wanted I need a small section of a bugeye bonnet Spridgets Classified 5
volunteer Wanted Need Door Seals, Vent Window Seals and Trunk Seal for Daimler ds420 Limo Jaguar Classifieds 23
Got_All_4 TR5/TR250 Need guidance for replacing steering column bushings Triumph 11
John Turney Need a Better Demister? Austin Healey 5
K TR2/3/3A Need advice on what my TR3A might be worth..... Triumph 10
69MGC MGC Need one MGB/C Splined Hub MG 1
69MGC Wanted Need one MGB/C Splined Hub MG Classifieds 4
Gliderman8 General TR Need clarification on Triumph Competition Preparation Manual TR250 TR5 TR6 Triumph 4
S TR6 Need wisdom on tr6 brake calipers Triumph 6
