NAPA master cylinder rebuild kits
Coastalman
Has anyone used the NAPA clutch master cylinder rebuild kit. I have a late model master cylinder on my BE and NAPA lists a rebuild kit for it. I think I will try it unless someone has had a bad experience with one.
Thanks,
Charlie
Tipsy
Charlie, my bad experience was with my master cylinder itself. I had to make a tool to remove the internal circlips to get everything apart. The regular tool that is made for this would not work. Then I discovered that the piston was scored so I decided to just get a new master from Napa. The cost was not that much more.
Jeff
Jim_Gruber
Charlie, I need to do the same. I'm told unless you really know how to do this the risk of scoring the bore to get out and reinstall the inner circlip is very high. Now if you can find some Lockheed NOS Dual Master's that may be the ticket. I need one for Bugsy to fix my basement carpet stairs issue. Car Carpet is awash in Castrol GT LMA that has a great affinity for the soles of TopSiders. Easily transferred to Basement Stairs. A no honey I have no clue where that oil is coming from. I think it's your car leaking in the driveway...
If you find a NOS please let me know.
Billm
I just got one from Rockauto.com and it is working very well- cost was good too.
BillM
C
Coastalman
I checked with my local NAPA dealer today. They do not stock the kit and would have to order it "from the factory" if I wanted it. I did not check for the complete cylinder, but I will. I will also check with Rockauto.com. Thanks for all the responses.
I did not have any trouble getting the piston out. The only circlip I had to remove was at the outer end of the cylinder and was very accessible. Am I missing something?
Thanks,
Charlie
Jim_Gruber
There is one more in there at the very bottom of the bore. I've never had it apart so I can't provide any more info just readng on this forum over the years.
JPSmit
There is and you typically need to destroy it. I drilled mine out but others have burned them out.
C
Coastalman
Now I can see why people would buy a new master cylinder. The trouble of rebuilding the old one is just not worth it.
Pythias
If you want one done right, get it off to Seirra.. contact through Gerard.
NFI
Jim_Gruber
A resleeve in brass is the permanent fix. Otherwise the alternative cheap stuff will need replacement is a few years and you need to do it all over again.
PeterC
Sorry to step in here, but I think y'all are talking about 3 different master cylinders. Coastalman would seem to have the 1967 single circuit brake master. An easy install in a Bugeye. JP and Jim seem to be talking about the 68 and newer dual circuit brake master, which is a problematic rebuild, and the problem isn't just the bore. And Bill L. is thinking of the original tandem brake/clutch masters.
Or, so it seems to me.
Funny
Peter C
Jim_Gruber
As usual Peter C you've been able to enlighten all of us. Thanks for the input.
C
Coastalman
Hey guys, I am working on the clutch master cylinder. It is the one with the plastic reservoir. I think from a '73 Midget.
PeterC
Wow...... yer right, the word clutch was mentioned... even funnier.
Yeah, the NAPA one will be the same as everyone else's... made in UK by Nelson.
Peter
nomad
BillM
I LOVE Rockauto!! Great source for inexpensive parts!
Kurt
PeterC
You DO realize that Rock Auto doesn't have anything IN stock? Just a cataloger and drop-shipper. Unfortunately, if you support those places, then you won't be able to get parts locally. just sayin'
Peter C
nomad
Sorry, Peter, for stepping on the toe's of guy's like you that are knowledgeable and the source for the correct parts!
My purchases from Rockauto have been for mainly Datsun parts that are being obsoleted and therefore greatly reduced in price. Their brit parts selection is quite limited and priced with the rest of the industry.
I thank you for your help in the past and highly recommend worldwideimport!
Kurt.
PeterC
No worries. You should see the obsolete Datsun parts we have!
They rubbed me wrong, once.... they used our logo on their website without permission. Took a while for them to take it down. Their office is a few miles away..... not in a warehouse district.
Peter
nomad
Peter, your point is well taken and your post got me thinking.
I avoid Walmart because of what they have done to mainstreet America and because of their predatory practices towards their suppliers.
We need more businesses that have actual people there to help in this hobby. I'm going to take a different point of view on this from now on!
Kurt.
nomad
Kurt.
T TR2/3/3A bad napa points Triumph 9
T TR2/3/3A Napa dot5 ok Triumph 4
tahoe healey oil sale at NAPA Austin Healey 4
glemon NAPA or other Parts Numbers for Triumph Parts Triumph 9
apbos TVR in NAPA Ca TVR 3
Newkie Napa Gold oil filter MG 5
C Castrol on sale at NAPA Austin Healey 2
A NAPA Radiator Hose Equivelent Austin Healey 11
AUSMHLY Oil filter, K&N vs. Napa Austin Healey 2
G TR5/TR250 NAPA U joints fro TR250/6 Triumph 5
Gray_Cat Bugeye For Sale in San Diego [and Napa] County Spridgets 4
J TR4/4A TR3, TR4 bypass hose needed , NAPA #? Triumph 2
L Removing Master Cylinder Without Paint Damage Austin Healey 27
L TRW-Lucas Brand Master Cylinders Austin Healey 2
71TR6 TR2/3/3A Aftermarket brake and clutch master cylinders - black extension? Triumph 6
6 Master Cylinder Rebuild Spridgets 6
K New Clutch Master/Slave Cylinder Austin Healey 1
wkilleffer MGB 1974 MGB clutch master cylinder questions MG 1
Racer-X- Frame mounted power brake pedal/booster/master cylinder kits for RHD cars? Restoration & Tools 1
Got_All_4 TR6 Which Clutch Master Cylinder Fork is for TR6 Triumph 4
bighealeysource Master Cylinder Installation Austin Healey 9
bighealeysource BN2 Master Cylinder Austin Healey 91
prb51 100-6 Brake Master Cylinder Bore Austin Healey 5
bighealeysource Brake Master Cylinder Austin Healey 27
A Brake Master Cylinder Freeplay Austin Healey 11
SNClocks Master Cylinder Bore Diameter Spridgets 0
W replace rigid master cylinder lines with flex. Spridgets 2
6 Master Cylinder Actuator rods Spridgets 2
6 Master Cylinder Install Spridgets 5
volunteer Wanted: Brake Master Cyl. Repair Kit for Daimler DS420 Other British Cars 18
K TR2/3/3A Clutch Master Cylinders? Triumph 1
rgfrey Bench Bleeding Brake Master Cylinder Austin Healey 2
K TR2/3/3A Clutch and Brake Master Cylinder push rod stop bolts? Triumph 15
R TR6 Clutch Master Cylinder Hydraulic Line (Thread / Flare Type) Triumph 4
gbtr6 Wanted: '96 LHD Drivers side master window switch panel. Jaguar Classifieds 0
mctriumph TR2/3/3A Defective master cylinders Tr3 Triumph 13
mctriumph master cylinder brake/clutch Tr3 Triumph Classifieds 9
R TR2/3/3A Master Cylinder Re-build Triumph 6
mrv8q TR2/3/3A Brake master cylinder: rebuild or replace? Triumph 9
D TR2/3/3A sealing master cylinder pocket Triumph 8
J For Sale Triumph TR 2/3 original brake/clutch master cylinder Triumph Classifieds 2
R TR4/4A Master Cylinder Corrosion Do I replace? Triumph 4
Rob Glasgow Ant Ansted Master Mechanic Austin Healey 4
BobHaskell MGB 1980 MGB harness question - brake servo/master cylinder MG 1
R TR2/3/3A 1961 TR3A Master Cylinder[s] Rebuild Kits Triumph 4
R TR2/3/3A Lockeed Master Cylinder Adapters Triumph 8
M TR6 Clutch Master Rebuild: That Crazy Wavy Washer Triumph 1
D TR2/3/3A master cylinder res plumbing and unknown spacer Triumph 6
D Clutch Master Cylinder Leak Austin Healey 20
