regularman
I have a question. On my wiper switch on my 71, it moves up and down for wiper speed, if you push in on the handle it runs the washer pump. Also you can move the handle forward and backward it snaps forward and back. I took this switch apart and cleaned it and put a bit of conductive silicone grease in it and confirmed there is a set of contacts that are made when the handle is pulled back. The colors of the wires going to it are white(ingition on hot) and yellow. I have not found a yellow on any wiring diagram. I am just wondering what its for? Again its not a momentary but a dual position switch on the wiper stalk just like the headlight dimmer switch on the turn signal stalk. If this is just some extra switch that is not used then it would be excellent for a backup light switch since I have the datsun transmission and had to remove the b/u switch for it to fit.
