Hi MrPandy. I am not sure if creative wiring has prevailed,but solid brown wires are used to route the unswitched 12 Volt power lines throughout the car. These three normally would connect to the fuse block.If the electrical system is operational you can check and see if there is the specified voltage at the ends of these wires and blank terminals on the fuse block.---Fwiw---Keoke
