My recent decision regarding oil in a '66 3000 with a rebuilt engine
shortsguy1
I am one of those people who spends way too much reading and researching things before I ever make a purchase. (It once took me two years of researching mountain bikes before I was ready to make a particular purchase. But 10 years later, I still ride that bike several times a week)
After reading all of the countless oil threads here and elsewhere, I originally decided to use Castrol GTX 20W-50 with ZDDPlus added at the recommended dosage. Sadly, I only got to do one oil change before it became clear that the engine had major problems (unrelated to the oil brand or viscosity, by the way).
The car is still a month or two from being done, but I have already decided to change to a new oil plan. Recently, I have read more and more recommendations to not add ZDDP to oil, as the detergents in the oil work against the zinc attaching to surfaces to protect them. So I decided to avoid using an additive, and instead find an oil formulated with an appropriate level of zinc in the oil itself.
As you know, there are many options out there for classic cars. I didn't want to use a racing oil as it may not be intended to last 3000 miles between changes. Racing oils may also not be well suited for a car that sits for weeks between use. I also wanted to use an oil for its intended purpose, so that meant that diesel oils were out. In the end, I contacted Joe Gibbs Driven oils for their recommendation.
They recommended their HR1 15W-50 conventional oil for a Healey 3000. This oil contains 1200-1300 ppm zinc and is designed for older cars and for cars that may not be frequently used. It costs $10 a quart, but there is a web vendor who sells it for $7. So it is not cheap, but not too expensive in the context that my engine rebuild will cost $8K.
They also said to monitor the oil pressure at idle when the car was warmed up. If the pressure at these conditions is 45 psi or higher, they recommend that I switch to their 10W40 oil at the next change. I will post my findings along these lines when they are available.
Anyway, I don't claim that my decision is better or worse than anyone else's. But I just wanted to share the thought process that I went through recently. Thanks for reading and I would enjoy hearing how others have come to use whatever oil they prefer.
Keoke
Use Valvoline VR1 30 to 40 weight and sleep well at night.
IT is formulated for racing engines.
N :" What's good for racers is good for old engines," :encouragement:
Oh !! your valve train-Flat Tappets- will thank you too.
DerekJ
Over this side of the pond I use Castrol 20/50 specially made for Classic Cars. I understand that isn't available in the States but I would have thought one of the US companies must make a special oil for classics.
vette
I've used Shell Rotella Diesel Oil for the last 15 years. No sign of burning oil or engine damage.
Keith_M
I think there are several brands that are suitable for our cars, but like Shortsguy1, I use HR1 15W-50. The HR stands for Hot Rod, and it is supposedly specially formulated to cling to vertical surfaces for longer than regular oil. This provides more lubrication on initial startup, particularly for cars that don't get driven every day (like most of our LBCs). I have no idea how true this claim really is, but it sounds good. :peaceful:
It's expensive for sure, but how often do you change your oil? Once a year, if you're like me. I buy my oil from the machine shop that did the work on my engine, and they sell it to me for around $7 a quart. With a spin-on filter instead of the original canister, my Healey takes 6 quarts, so that's $42 a year, plus filter. In the grand scheme of things, it's just not that much.
Of course, if your car burns or leaks a lot of oil, or if you have a fleet, then the price goes up accordingly.
EV2239
I use Mobil 1 10W60 for Classic cars and one day the same stuff turned up but with a label saying is was for racing cars, so I rang Mobil and discovered that the two formulations are identical. What's good for racers is good for old engines, which seems eminently logical. One is highly stressed because it revving extremely hard, getting very hot and being beaten up by a driver anxious to prove himself. And the other suffers all the same issues because it's and elderly over stressed design.
I'm doing 500 miles on cheap 20W50 then back to Mobil 1 after I watched lots of Mobil videos on YouTube explaining all the benefits and its suitability for old crabs. Then I found the one where a BMW 325 did 1,000,000 miles on it without any wear and various Merc engines the same.
PHulst
Bronze
Same here. Diesel oil may not be originally designed for classic cars, but it meets every spec it should for an older engine.
There is a new diesel oil spec in the works, and the upcoming CK-4 standard is supposed to be backward-compatible as well.
I can't find any published data as to proposed ZDDP levels for it, so we will have to see how it turns out.
Straighten me out here. I have always been under the impression that the first, low number was for cold weather starts. Too thin for above 60-70 degree weather. The higher number for running when the engine is hot/warm to keep lubricant working. Why would you want to increase the wear when warming up with a weak oil?
Keoke
Well,Not really TH:
When you see a W on a viscosity rating it simply means that this oil viscosity-it's ability to flow- has been tested at a Colder temperature. The numbers without the W are all tested at 210 degrees F
OH!! Faster engine turn over at low temps starts sooner.,less wear.
John Turney
Not quite.
If an oil has only one viscosity listed, like SAE 50, it has the viscosity of an SAE 50 oil at 210 degrees and at the colder temperature (IIRC 32 deg.)
If the oil has two viscosities listed, like SAE 20W50, it has the viscosity of an SAE 20 oil at the cold temperature and the viscosity of an SAE 50 oil at 210 degrees. To do that, it usually requires some modification of the oil (viscosity modifiers).
The viscosity ranges are listed in the SAE Standard for each temperature.
John Turney
That's going to take some time to read. It is, however, less expensive than Which Oil? Choosing the right oils & greases for your antique, vintage, veteran, classic or collector car by Richard Michell.
DerekJ
John,
I have now read it twice and will read it again. At the moment however I am planning to change to a thinner synthetic oil at the next change. (Maybe EVV can comment on why he goes for the 60 grade at operating temp). One interesting stat is the 'optimum' oil pressure of 10psi per 1000 revs. Mine is higher than that as are most others I suspect. But as he says, flow lubricates the engine not pressure. High pressure may simply be the result of clogged 'arteries'. Enjoy the study!
John Turney
I somewhat disagree with his wording:
In fact the relationship between pressure and flow is in opposition. If you change your oil to a thicker formula the pressure will go up. It goes up because the resistance to flow is greater and in fact the flow must go down in order for the pressure to go up. They are inversely related. Conversely if you choose a thinner oil then the pressure will go down. This can only occur if the flow has increased.
The flow rate of oil is determined by the speed of the positive-displacement oil pump. For any given RPM, the flow rate of oil will be close to constant regardless of oil viscosity. A higher viscosity will increase the pump discharge pressure and sap power by making the pump work harder, but the flow rate is only slightly affected. He is correct that oil flow rate is more important than pressure, mostly because of the cooling provided by the oil.
DerekJ
John,
Although the flow rate will remain the same the pressure will increase if you use a higher viscosity oil. He seems to say that an optimum pressure is 10 psi per 1000 rpm but I don't really know why and whether that applies to all/most engines. I am at 50 psi at 3000rpm. Thinner oil is clearly not a bad thing and will increase fuel consumption and aid cold starting amongst other things.
Healey Nut
After reading this I have come to the conclusion that you guys are all retired and spend way way way to much time reading stuff and specs and and and .......Put in some 20/50 Castrol GTX and drive her like ya stole it:eagerness::welcoming::eagerness::welcoming:
Keoke
S Any recent experiences with rear leaf spring vendors? Austin Healey 31
MadMarx Wedge IMSA TR8 - a recent photo Triumph 3
aeronca65t Recent Sitings-NJ Spotted 0
PC two recent sightings... Spotted 0
JodyFKerr Pic from our recent Triumph Club meeting Triumph 6
Sherlock Recent sightings Spotted 10
pjsmetana Some recent Before/After pics :] Triumph 8
Bone My recent purchase Spridgets 10
aeronca65t Recent Photos-race MGs MG 1
aeronca65t Recent Photos AH racers Austin Healey 2
aeronca65t Recent Mini Pictures British Motor Corp 1
bmurphy7369 Let's Help Basil with Recent Cost Issues, Ideas... Austin Healey 0
bmurphy7369 Let's Help Basil with Recent Cost Issues, Ideas... Spridgets 0
bmurphy7369 Let's Help Basil with Recent Cost Issues, Ideas... Triumph 0
Jer Recent Spridget Adventures ? Spridgets 15
drooartz eBay Bugeye fuel tanks, recent experience? Spridgets 8
1965_MGB Most Recent Moss Sale MG 2
D My recent purchase........! MG 1
J Recent Ebay sale Triumph 2
Randy Forbes Recent projects; long time coming... Austin Healey 16
rick_ingram MG 2006 - My Most Recent Gatlinburg Visit MG 31
G Recent outing with pics Austin Healey 3
H Recent BJ8 purchase- advice please Austin Healey 8
NutmegCT recent tweaks MG 7
T Recent Sunbeam Event [link] Sunbeam (Rootes) 5
drooartz MGB Made a decision, my MGB is going... MG 102
Got_All_4 TR6 Cam selection decision time could use your thoughts Triumph 2
Pythias Made the decision to sell. Spridgets 6
Kleykamp TR2/3/3A Radiator decision??? Triumph 17
A Sad to say, but it's decision time - Sell whole or part out? Spridgets 12
B TR6 TR6 decision on header/manifold/exhaust Triumph 4
G How do I know I am making the right decision? Jaguar 7
KLUTZ Help me make a decision please.. MG 7
drooartz Sad decision Spridgets 17
David_K HELP! BJ8 Wire Wheel/Tire Decision Austin Healey 11
Rob_P Decision needed for wheel choice.... MG 36
drooartz Engine decision made, gonna be a fun winter! Spridgets 21
budk1953 A Good Decision.... Spridgets 2
drooartz A decision made for more power Spridgets 24
S TR2/3/3A Proof of non-black TR3 frames! Plus decision time Triumph 6
Randy Harris Having made the fateful decision.. Jaguar 0
Celtic 77 MGB Looking for best info regarding throttle cable replacement. MG 16
Y MGB Pitfalls and cans of worms regarding MGB flywheels MG 12
jlaird MGB This weeks werd question regarding steering racks. MG 3
Ripper01 TR6 Inputs regarding Simonbbc Ignition Solutions Triumph 0
tr6nitjulius TR6 @Triumphest 2019 Committee Meeting 8/3 regarding TR6 50th Birthday Triumph 0
S Question regarding NOS vs New rear leaf spring bushings Austin Healey 3
stretchit2 Question regarding BN7 Hardtop Austin Healey 7
A TR2/3/3A Newbie Question regarding Girling rear brake cylinder Triumph 5
R TR4/4A Need Advice as to what to do regarding Engine Compression Problems Triumph 26
