T
Tinster
Well, the rig ain't real pretty to look at but
both horns do indeed now beep when I push the
horn button.
I got to thinking how lazy DPO Pedro's junkyard mechanic
was. I could not believe he would go to the trouble to
remove the steering wheel hub and then remove the plastic
disk with metal contact strip out of the hub.
I dug around a little ---he didn't. It's still there and
best of all; it's functional. I found a purple/black wire
stub. Ran my new Dan Masters wire to the old wire.
I soldered a purple/black wire to the brass springy thingy
and drilled a ground wire lead into the steering shaft
large securement nut.
Ain't pretty but it honks!! Thanks all for the advice and
help. Another score for Amos!!
d
horn button.
d
Hi Guest!
