trrdster2000
The pin came out at the pump. The weight of the shaft should keep it in the pan, unless you are going in the BAHA 1000. It should not stop you from getting it running, but when you can get the pan gasket, drop it and clean it while you are in there. Be careful with the front bolts, they go in aluminum. If you have a torque wrench be sure to use it.
Wayne
Wayne
