TR6 My '74 TR6 Zenith Stromberg Carbs Float Bowls Leaking Gas
TR6Dan
I am not sure what the problem is (why I am here). I have swapped by float bowls which have plastic plugs for late 70s bowls from MGB with no plugs; thought the float bowl plugs and new O-rings might be leaking along with leaking gas past the gaskets; the latter which to me sounds like the bowls are filled with gas all the way to the top ( I would think they should only fill to about 1/2 full). Thought it might be the needle valves allowing the bowls to fill to the top; so replaced them with GROSE-JETs, checked and adjusted the float height above the carb surface for the correct ht. (about 16-17mm); they both are still leaking gas past the gaskets. Please help me with what the problem could be.
Thanks,
Dan
poolboy
What are you using for a fuel pump ?
And don't discard the plunger type needle valves....Grose jets tend to leak more often than needle valves.
T
TR6Dan
I am using a mechanical pump from Moss Motors. Installed about 2 years ago; car has run fine since replaced.
I still have the plunger type valves replaced with Grose jets; leaked and filled bowls with both. If they are working properly; shouldn't the bowl not fill to the top but about 1/2 way up?
poolboy
I don't know about the "1/2 way up" part, but at 17 mm the floats should put enough pressure on the needle valve to shut off the fuel when the proper level is reached.
You could check the floats for bouyancy and have a look at the float pivot bracket...but to have both carbs over flowing would be unusual in those scenario.
T
TR6Dan
I measured the float level at 17 mm per the manual and adjusted to fit that. Floats looked fine and did not seem to contain gas and pivoted fine. If the valves are working correctly I would think the bowls would not be full; and the bowls must be full to have gas leaking at the gaskets. Have done the same thing with both the old and new valves. Not sure what to do now.
poolboy
If all that checks out...fuel pressure, float bouyancy, float height, float brackets, proper gasket installation, needle valves working.... then the only other thing I can think of is excessive air pressure within the float chamber...What
do you have connected to the float chamber vent nipples ...the 'red' ones ?
poolboy
Since it's simple to do, unplug that hose from the Carbon Canister and see if the leak stops....I don't see why it would matter but just try it.
Sarastro
Sorry, I'm not familiar with the ZS carbs used on the TR6, but I am familiar with the TR4A ones. Still, here's what I found:
The O-rings used on the jet assembly, which seal between the assembly and the float bowl, are not really sized right; I suspect they are the closest modern size to something now NLA. I think they probably work when there is minimal wear of the surfaces against which the O-rings seat, but in our 50+ year old carbs, sometimes not. I replaced mine with slightly larger O-rings.
It wasn't clear to me where your leak is coming from. If fuel is coming from the jet assembly, this might be your problem.
See http://tr4a.nonlintec.com/external/#fuel_system for my experience; scroll down to "A Tale of Two O Rings"
T TR6 Carb Vacuum Port- TR6 Zenith-Stromberg Carbs Triumph 4
I TR6 69 TR6 Zenith Stromberg carb help Triumph 1
G TR6 Zenith Stromberg [1973 TR6] help Triumph 5
RomanH TR6 TR6 Zenith Carb Problem Triumph 5
C For Sale 69 Triumph TR6 Racecar Triumph Classifieds 0
R TR6 Crazy Ignition Failure in TR6 engine… Triumph 7
mctriumph For Sale 69 Tr6 Triumph Classifieds 1
B TR6 TR6 block decking Triumph 2
A TR6 How many fuel filters-TR6 Triumph 25
Got_All_4 General Tech TR6 Transmission Troubles Pops Out of 3rd gear Triumph 2
J TR6 Repadding TR6 frame Triumph 0
S Wanted Need an HVDA conversion kit for 73 TR6 Triumph Classifieds 3
M TR6 Sorting out new TR6 Triumph 10
S TR6 '72 TR6 distributor issues Triumph 3
R TR6 Limit Mechanical Advance on TR6 distributor? Triumph 8
B TR6 TR6 convertible top frame Triumph 0
K TR2/3/3A The TR6 gearbox Ist gear.... Triumph 1
tr6nitjulius For Sale TR6 tail light assemby & Resurfaced/New Ring Gear Flywheel Triumph Classifieds 0
tr6nitjulius TR6 TRIUMPH TR6 Triumph 7
S TR6 New tr6 purchase Triumph 31
nichola TR6 Hot spot on cylinder head - 1973 TR6 Triumph 2
R TR6 Heater control bezels TR6 Triumph 2
L For Sale 1974 Tr6 for sale Triumph Classifieds 0
tr6nitjulius TR6 TR6 Parts Visualization Triumph 0
Got_All_4 For Sale 1969 TR6 Driver Seat Triumph Classifieds 0
R TR6 TR6 Choke Cable Triumph 11
Got_All_4 For Sale TR6 TR250 TR4 parts for sale Triumph Classifieds 2
B For Sale TR6 Carburetors Triumph Classifieds 0
R TR6 TR6 Triumph 6
Chrisc9 TR6 TR6 brake light Triumph 6
tr6nitjulius General TR TRIUMPH TR6 the possibilities! Triumph 12
SherpaPilot TR6 Unidentified fitting on TR6 Engine Triumph 3
Got_All_4 TR6 Need 1969 TR6 Expert Got Questions Triumph 17
AngliaGT ANOTHER TR6,& an MGB Spotted 0
A For Sale 1974 TR6 Triumph Classifieds 1
Got_All_4 TR6 Triumph TR6 PDWA Brake Question Triumph 1
EWD For Sale ‘74 TR6 original wheel trim rings Triumph Classifieds 3
EWD For Sale ‘74 TR6 original radio Triumph Classifieds 0
EWD For Sale ‘74 TR6 original starter Triumph Classifieds 0
EWD For Sale ‘74 TR6 original steering wheel Triumph Classifieds 0
JPSmit TR6 at lunch today Spotted 0
E Wanted looking for a tr6 bell housing Triumph Classifieds 12
jfarris For Sale TR6 Yellow Fan - new Triumph Classifieds 0
L Wanted right front turn signal 1975 TR6 Triumph Classifieds 2
charlie74 ‘74 1/2+ TR6 Spotted 0
