DrEntropy said:
You did plug off the vacuum ports at the carbs as you did this, yes?
darn!! Doc,
Will I ever got this timing procedure correct?
1. I unplugged both pipes on my twin dizzy ears and set them aside.
2. I plugged up the nipples on both dizzy ears
3. I connnected my vacuum gauge to the intake manifold nipple( - 20 )
4. I disconnected the carb throttle linkage.
5. The rubber hose connnecting the carbs remained in place
6. I started the car easily without using the choke.
7. At reaching 160 warm temp, I rotated the dizzy until I
had 10* advance. I checked each wire for fire. All good.
8. I fiddled with the idle screws to get 850 rpm and balance bubble
up halfway for both.
9. I installed 2 new plugs gapped to .025, 2 cleaned existing gapped
to .025 and 2 sooty existing gapped at .025
10 I reinstalled all the various hoses and pipe.
11. I put my carb mixture tool into the dashpot top, locked it inplace
and counter-rotated the hex tool about 30 degree per carb to lean out misture.
12. I now have the carb linkage off and am trying to straighten the bent links flat.
Please review and call out any blunders!!
thanks,
dale
