Mounting Bracket for Bugeye, Water/Oil Pressure Gauge
paulsherman
I am just now re-assembling my dashboard and I have found that I am missing the bracket for the water/oil gauge. It looks like it would be easy to fabricate, but like most everything i do, I am over thinking it. I have another bracket that is the wrong one, but it has grommets (nylon) where the bracket mounts to the gauge (2 holes).
Now my question: Is there need for grommets in the bracket I will fabricate? I am thinking (over thinking), that this gauge should or could be insulated from the ground and need grommets?
Also, I am missing the hardware that holds the turn signal green jewel. I have the jewel and the chrome piece that holds the jewel. Anyone have this hardware they would love to part with?
Thank you.
Paul
nomad
Paul, if you have the original oil/temp gauge you will need a place to mount the light on that bracket as well.
Can't help on the jewel....those part's may be unobtainium!
P
paulsherman
Obi;
I have the bracket for the gas gauge, so can fabricate (hopefully) a bracket for the water/oil gauge. with a holder for the bulb, using the gas gauge bracket as a pattern.
Paul
dklawson
Other than as a vibration dampener, I can think of no reason why the oil/water gauge should need to be insulated. The capillary tube and expansion bulb for the gauge are metal and grounded. The oil pressure is mechanical and sections of its line are also grounded. For the illumination to work you will need a ground connection for the bulb mount anyway.
Got_All_4 TR6 Seal To Body Mounting Bracket Welded? Triumph 7
K 100-6 Exhaust Front Mounting Bracket Austin Healey 2
R Wanted ISO: Main Link to mounting bracket screw Triumph Classifieds 0
matmire wishbone mounting bracket repair. Spridgets 3
D Gauge and Switch Mounting Bracket Austin Healey 27
N Spitfire Fastners for mounting heater control valve and bracket Triumph 12
H IRS diff rear mounting bracket Triumph 0
I TR6 TR6 lower mounting bracket help Triumph 5
chicken Exhaust mounting bracket quiery Austin Healey 5
MadRiver Bracket for mounting driving lights to badge bar? Triumph 7
S TR2/3/3A tr3A mounting bracket slave cylinder Triumph 7
W Need a master cylinder mounting bracket Triumph 1
J SOLD!! Triumph TR 2 TR 3 windshield stanchion mounting plates Triumph Classifieds 3
J TR2/3/3A TR2 Fitting/mounting rear wing Triumph 11
angelfj1 TR5/TR250 TR250 - Lucas 4ST Starting Solenoid-Mounting Location/Details Triumph 2
K TR6 Goodparts Trail arm kits mounting just to the frame( no body) and shims? Triumph 9
SherpaPilot TR6 Engine Mounting Question Triumph 3
B BJ7 Rear View Mirror Mounting Hardware Austin Healey 7
WHT Late BJ8 Seat Belt Mounting Points Austin Healey 8
T TR2/3/3A Question on TR3A front body mounting Triumph 6
T SU Fuel Pump Mounting Austin Healey 5
Darwin Spitfire Motor mounting help Triumph 1
Got_All_4 TR6 Distributor Gear Mounting Question Need End Float Washer Triumph 4
chicken BJ7 Rear Number Plate Mounting Austin Healey 3
Healey Nut Rear Wheel Cylinder Mounting Austin Healey 4
S TR2/3/3A Body Mounting Bolts. Triumph 14
M Mounting BJ8 Chassis on Rotisserie Austin Healey 8
D BJ7 Hood frame mounting plate Austin Healey 7
Editor_Reid H6 Carb Mounting Austin Healey 4
M Wanted TR6 Caliper Mounting Plate Passenger/RH Side Triumph Classifieds 1
T TR2/3/3A TR3A Hardtop Rear Mounting Brackets Triumph 15
K TR2/3/3A Upper shock mounting rubber bushs ? Triumph 1
B For Sale Seat Mounting brackets for aftermarket seats Spridgets Classified 0
C Front sway bar mounting? Austin Healey 10
B TR2/3/3A Mounting Toyota Brake Calipers on my TR3 Triumph 5
J TR2/3/3A Body Mounting Strip Adhesive Triumph 10
Gliderman8 TR6 Inertia switch mounting location Triumph 4
K TR2/3/3A Front brake caliper mounting torque? Triumph 1
BoyRacer windshield wiper motor rubber mounting grommets Austin Healey 9
S TR2/3/3A Mounting a stock steering wheel. Triumph 3
F TR2/3/3A Mounting Slave Cylinder Triumph 41
K TR2/3/3A TR4 motor with overdrive in a TR3 slave cylinder mounting position? Triumph 2
RickPA Mounting number plate on front bumper Austin Healey 4
R Mounting rear shroud rain gutter Austin Healey 14
R Mounting wipers Austin Healey 8
Raymond MGB Wire Wheel Tire Mounting MG 0
T General TR Wire wheels - tire mounting/balancing - Southern California Triumph 14
SASSAMON Wanted WTB Early Sidescreens and mounting hardware for TR2/3 Triumph Classifieds 4
G Steering Column Mounting Austin Healey 1
red57 1960 BT7 top mounting brackets Austin Healey 4
