I find my 3 is hunting with more play than I like at speed. It is not comfortable especially with the over-steer that it already has. I am not closed to going through the existing steering, in fact I haven't really even looked at it for years. But already being there to replace the radiator, installing the rack is almost done anyway.
The rack for the TR3 is not the quick rack so I'm not too worried about that, nor the control head so much. I hadn't heard however, that it increases the steering ratio. That I'm not liking.
What stops the head from turning with the wheel ?I have retained the original control head by using Bastuck's steering column modification, only losing the self cancelling function.
really? If the control arms are swapped, the geometry that causes bump steer goes away. Theoretically, I guess...Just FYI if you are going for the R&P change. A fellow club member used the Revington kit and he has bump steer also. So that issue is not dealt with on either kit. But, you get choices for the turn signals depending on which you use. I now have a MGB type turn signal on the side under the steering wheel. Not that noticeable and it works.
I used to think that, too. Went over 100,000 miles with my previous motor and never had a problem. But now my TR3 is sitting with a crankshaft broken through the front web. Might just be a manufacturing defect that didn't show up for 60 years, but sure seems suspicious to me. The replacement crank will be getting a damper.Neil Revington swears a harmonic damper is not needed, so none used,.
