GTP1960
I installed the Moss narrow belt conversion a couple of years ago ( maybe 1000 miles ago.)
"837-508 or TT1132 Pulley & 3/8 Inch Belt KitConverts TR 2-4 Four Cylinder Engines to 3/8” Fan Belt "
It worked great.....right up until it failed.
Three questions here:
1) has anyone else had a similar problem with their vib. dampening pulley?
note in the pic: the metal failure at the woodruff key slot and the reaming effect of failure.
the pulley bolt was snug & tight.
2) what do I do if the crankshaft end is ground down also ?( like the pulley boss)
3) anything I could have done different to avoid this?
Thanks for for any advice.
Hi Guest!
