CJD
I hear ya'. There was a time I would have thought the same, and Moss is also very confused.
A damper is a heavy iron ring held to a steel hub with an elastomer...or rubbery...material. Every time the engine fires it puts a pulse into the crank, followed by the next, and the next. At certain speeds the frequency of the cylinder pulses matches the resonant frequency of the steel crank. It's hard to picture, as the crank seems very stiff, but like any steel part, it is similar to a very stiff spring. If you twist it at the right frequency back and forth, it increases the amount it stretches.
Piston aircraft engines often have warnings NOT to cruise at a particular RPM for just such resonant reasons. I've seen huge aircraft crankshafts sheared right off from resonance fatigue.
What I am trying to get at is that the load on the damper has very little to do with the pulley size, the fan, or anything like that. The resonant loads are an order of magnitude higher than any of these. So, reducing the bolt because of the belt or fan is just craziness.
