When assembling the the trunnion to the vertical link....how much of a gap should you end up with where they meet at the seal?...the way it seems now the seal is kind of flapping around rather than being slightly compressed. I cold almost turn the trunnion another turn but the brass stop casting slightly hits the vertical link. Being an aftermarket trunnion I'm wondering if it should go one more turn and then backed off?....the casting could be lightly filed to accomplish this. Also the manual says" screw trunnion home without forcing and then turn back one complete turn,and then positioned so that the shackle pin lies parallel to the body of the car,but inwards,between the base of the vertical link and the chassis frame as the shackle pin is offset." What is the shackle pin and what exactly are they getting at here? Any advice on this welcome. Karl
