Proceeding along. 2 questions:
1. Where does the starter solenoid mount? Can't find the corresponding 2 holes.
2. I got the moss #680-428 seal set to use with the poly gear box cover. Not quite sure how seals fit. Glue them to cover or to the floor? Is there enough to seal the handbrake tunnel cover too?
By the way, I used the speedbleeder.com and they really worked great. I only needed 4 including the clutch slave since there is no bleeder on one rear cylinder as it crosses over to feed the other side. I ordered 5.
I'm sure there will be more questions later. Sadly it was 15 or 20 years ago when I stripped the car down and I have trouble remembering last week.
Al Shoop
Al Shoop
Hi Guest!
