Bruce_B
(1) I see that the dimmer switch wiring comes up
by the clutch/brake box. Does anyone have a picture or know where the harness routes across to get in touch with the main harness? I've got the wires hooked up OK, high/low beams working fine, just not sure of where to place the harness.
(2) Under the dash, where the harness goes through the firewall to the engine comparment, just befrore the grommet (inside the car), there's 3 or 4 wires that are 'hot'.
Not sure where these go. Do they connect to the rear harness, or does the rear harness go through the firewall grommet to plug into the connectors that are right by the firewall?
FYI - I'm using the Bugeye Wiring poster that's sold on Ebay - very helpful. Two others things that are needed - a VOM meter and a explaination of th Lucas color codes...and beer.
Sure is nice working with clean wires that actually have color codes other than greasy black and dirty grey!
Thanks.
Thanks.
Thanks.
Thanks.
Thanks.
Thanks.
Hi Guest!
