When I disassembled the rocker shaft assy. I found that the rocker shaft was worn. I am going to replace the rocker shaft and was wondering if any on is using the Nylatron spacers from Moss instead of the side load springs. I am considering replacing the rocker arms also.
I thought I saw a reference about a vendor for the rocker shaft assy. That may be the best way to go if not too expensive.
Thanks again, Pete
Thanks again, Pete
