MK IX Gross Weight ? Wheel Offset? Gas Capacity?
Michael J.
I'm looking at tires for a MK IX and need to determine the loading for the tires. What is the Gross Weight for a MK IX?
What is the fuel capacity? The fuel tanks look small, as if each could hold only about five gallons.
What is the proper wheel offset/back spacing for the 6" rims on a MK IX?
LarryK
Fuel Tanks: Left side 8 gals. Right side 9 gals.
Weight 34cwt (dry)
That's all I see in the manual.
M
Michael J.
Larry,
I stumbled across an article on the MK VII 50th aniversary in the September/October 2000 Jaguar Journal. It indicates that 34.5cwt is equal to 3,865 pounds. That article indicates that MKVII from 1952 had 16" X 5.5" rims and 6.70 X 16 tires.
The car has 15" American Racing Mags on it. I can find a good replacement similar to original if I can get an idea of what the offset should be. Somewhere, I saw mention that a MK IX had 16 X 6" rims.
Any idea on the correct tire size for a MK IX?
LarryK
Michael: I found the MK IX is 4080 Lbs. in one of my books. Chris Harvey in his Classic Jaguar Saloons says 36.5CWT. Also the correct wheel size is 16 X 5.5. The MK VII had 16 X 5 until 52 the went to 5.5. Your 6.70 X 16 is right. The MK VIIM had same and it continued thru the MK IX. I cannot find or a mention of offset. I would figure the rims you have, looking from front: If the tyres are flush with fenders then measure offset of that rim. Do you have a spare, original? I sent you an email and picture of a Road and Track test in 56' of the VII, which is same except for some gear sets changes and brakes etc. I'll keep looking, will take awhile as I have quite a library and British Mags dating back to the eaarly 70's.
M
Michael J.
I was able to purchase a set of MK IX rims, although I will be sandblasting on them for a while.
I'm going to use 215R70 X 16 tires. Someone on JagLovers.Org has this size on a MK IX and seems to have adequate clearance.
LarryK
Clearance might not be an issue. Diameter may change speedometer. 205s might be closer in diameter. Check tirerack for diameter cross.
S TR2/3/3A Gross jets tr3 Triumph 7
tweety She's a gross polluter! Spridgets 10
Michael Oritt 100 Flywheel Weight Austin Healey 16
T Weight of BJ7 Transmission/Overdrive Austin Healey 10
T TR2/3/3A Body Tub Weight Triumph 8
X Technical specifications including the maximum technical weight TVR 8
S TR2/3/3A What weight transmission oil in a tr3 with OD? Triumph 13
H MGA MGA engine weight? MG 3
TRMark TR4/4A TR4 Weight Loss Program Triumph 6
banjojambo TR2/3/3A TR3A adding weight to improve handling Triumph 5
R Engine component weight reduction Austin Healey 53
BoyRacer weight of bare Healey chassis Austin Healey 8
T TR2/3/3A TR-4 Tail shaft counter weight Triumph 4
kennypinkerton MGB Body shell weight? MG 3
kennypinkerton MGB Rubber bumper weight surprise.. MG 4
BOBBYR Frame weight Austin Healey 14
T Weight of a Bug-Eye bodytub: approx 220 pounds Spridgets 10
Willie_P TR4/4A Weight Weenies: Tr4 relo of battery to boot...good idea? Triumph 6
glemon General TR Weight Loss Program Triumph 9
GeorgeC Hardtop weight? Spridgets 6
Griz Engine weight Austin Healey 13
2billydavies TR2/3/3A engine fan assembly on TR3a: balance weight question Triumph 3
R weight of BJ8 Frame with inner body panels Austin Healey 1
P 1275 Weight?? Spridgets 3
D Engine weight Triumph 4
O TR2/3/3A TR3 Overdrive Weight? Triumph 6
5 TR2/3/3A TR3 bare shell weight Triumph 9
G RB weight sans driveline and bumpers? Spridgets 5
T Weight difference beween steel and wire rims Triumph 11
S Weight of Bugeye unibody Spridgets 2
T TR2/3/3A What weight gear oil to use in TR3 transmission? Triumph 23
M 3.0 iron weight difference Austin Healey 7
J Another pic of the E-Type light weight Jaguar 0
G Spitfire Weight diff b/w Spit 4 and 6? Triumph 3
A Rear end weight? Austin Healey 7
J TR2/3/3A TR3 tub weight? Triumph 16
B Engine Oil Type and Weight? Austin Healey 8
Frankenhealey Aluminium everything - weight saving? Austin Healey 3
hilsideser Spitfire Spitfire frame weight? Triumph 6
B Rear Clip weight Triumph 2
Ken40 MGB-GT MGB/GT body shell weight MG 3
B Race spridget weight jacking Racing 8
aeronca65t Corner weight setup Racing 3
K Curb weight Triumph 4
BionicHealey Chassis Weight Austin Healey 13
PatGalvin TR2/3/3A TR3 Flywheel Weight Triumph 9
B piston/rod assembly weight Austin Healey 0
B Need for piston/ rod assembly weight Austin Healey 4
vette Engine Weight Austin Healey 19
healeyboz flywheel weight Spridgets 2
