I like this approach! Sorry for the delay. I had to make a holder for the drop dial since I don't have a magnetic holder. I'll attach a pic of the setup. I ran each test three times to show variability in the test setup. At the point of balance on number one cylinder the exhaust was open. .025, .023, .025. The intake valve was open .033, .032, .033. The engine was cold and tappets set at .012. Looking back at it, I probably should have set tappets at zero clearance. All rotations were clockwise.I've been lurking for a while and finally decided to join the thread.
My immediate reaction, on reading the initial post, was valve timing. I agree with Graham on that. It's difficult to check this without a degree wheel. One thing you might try--and I don't know for sure if this will work--measure the amount that the #1 valves are open at TDC on the exhaust stroke. They should be the same. The intake valve will be opening and the exhaust closing, but at that point they should be the same distance from fully closed. Be sure to approach this point turning the engine CW as seen from the front.
Another possibility: adjusting the carbs should be done with the engine fully hot. Just warming it up in the driveway generally is not enough. But, I suspect that would leave it too rich, and the popping indicates a lean mixture.
When I'm adjusting the carbs, the connecting rod between carbs is loose per the manual. After adjusting, I tighten the clamp and check for slippage.There is a connecting rod that clamps both carbs together. When you move the throttle, do both carbs move together? The clamp could be slipping on the rod and your car might be running on one carb.
If you can see the springs on the valves close and open, you lobes are probably fine. When the lobe is gone, there is no movement.
steve
I checked valve lift on all valves and the lift ranges from .356 to .365 and everywhere in between. It appears like there isn't a worn lobe and all are wearing pretty evenly. Do you know how much the valves should open?I like this approach! Sorry for the delay. I had to make a holder for the drop dial since I don't have a magnetic holder. I'll attach a pic of the setup. I ran each test three times to show variability in the test setup. At the point of balance on number one cylinder the exhaust was open. .025, .023, .025. The intake valve was open .033, .032, .033. The engine was cold and tappets set at .012. Looking back at it, I probably should have set tappets at zero clearance. All rotations were clockwise.
The difference is about .010 inch. I rotated the crank to move the dial .010 and I saw the pulley mark move about 1/8 of an inch. I rotated the crank to move the dial .010 and I saw the pulley mark move about 1/8 of an inch. If I did the math right this is about 2 deg. of rotation. Let me know your thoughts. In the meantime, while I have the setup, I'll check valve lift on the other cylinders to see if I have even wear on the cam lobes.
I think you're getting way to deep. You have an off-idle lean mixture.
Check for vacuum leaks.
Ensure correct needles.
Check the float levels.
Check for actual timing at idle and off idle.
check connections to and from the coil that would cause a weal spark.
You would not have a good idle like you do if anything mechanical was off. And, I understand you have new parts and have checked these items. But the problem will lie in one of the above.
Thanks for the input. I was extra careful when putting the needles in the piston and the shoulder is flush with the piston bottom. Screws are tight. I've rechecked them to make sure they aren't moving. My latest "discovery" is with the timing light showing an occasional spark occurring in number one cylinder about one inch on the flywheel btdc. The spark fires six or eight times at 5 deg btdc and once much earlier. I don't understand how this is possible.Ken,
In your recent post you referred to the needles as CM. I am sure you meant SM as you previously stated.
Your large number of flats to adjust the jets got me to thinking. Why? My best guess is that your needles are not properly fastened into the piston. Each needle has a "shoulder". The bottom edge of that shoulder should just be exposed or even with the bottom of the piston. When the needle is to low with the shoulder exposed below the piston your needle settings are all off. Which would require the extra flats to adjust the jet. Additionally this also means that the float settings are off. The needle/ shoulder height is like the first domino to fall and then each of the other adjustments must be altered.
Charley
No, the radiator isn't new but was recored about 25 years ago and I have the original fan which isn't very efficient. I live in Florida and the temp is around 90F. I've always had overheating when the car idles for 15 minutes or more.You put in new radiator. Was block flushed? Should not overheat on idle. Especially with the low presssure cap. Too lean can overheat, but something is missing in this equation.
I'm thinking that I may need to revisit the passage between the float chamber and the jet to see if something is blocking flow. I ran a wire through it once before, but it's been a while.Graham,
Have you ever heard of needing to turn 20 flats down to adjust the jets? I believe there is a reason .
Ken's answer was not after he checked. I am suggesting what he thought was correct may not be.
Charley
