Midget missing VIN tag....what to do???
Re: Midget VIN decoding
[ QUOTE ]
Also by the Pasanger side bonnet hinge. on the flat piece of sheet metal just above the hole for the right hand drive brake-clutch cut out. the body # should be stamped there. This should match the tag on the door frames.
[/ QUOTE ]
Ok. I have a fuse box there which might be a replacement. How far above the cut out plate would it be? You see I have some sort of rubberized black paint coating the whole engine bay. I'd have to start taking a wire wheel to the area. I'd like to know where to start.
Are the numbers running verticle or horizontal?
Horizontal about 2 to 3 inches above the cut out. There just stamped in the tin very lightly on the 2 that I had
There right on the# on the shock mount. It is not on bugeyes.Just went back and saw yours is a 65. There should be a stamp right behind the shock, on the flat plate were it boltsdown to the frame behind if you are standing in front of the car. This should match the vin #
Email me here beedle@verizon.net I my have a cure for you..
Found the number stamped on the pass side shock mounting plate
It was stamped as GAN458084 so I guess that would be:
GAN-4-58084 Clearly a 67 MG Midget. Engine plate seems to be the original engine as well as it's a 12CC coded engine.
Glad you found the numbers. Hope you can get a registration /ubbthreads/images/graemlins/savewave.gif
It's not a question of if it's a question of how much money. From what I understand about $100-$200.
I have almost $200 in mine. In Pa its a one time thing. No yearly registration cost. /ubbthreads/images/graemlins/driving.gif
