Re: Midget VIN decoding
[ QUOTE ]
Also by the Pasanger side bonnet hinge. on the flat piece of sheet metal just above the hole for the right hand drive brake-clutch cut out. the body # should be stamped there. This should match the tag on the door frames.
[/ QUOTE ]
Ok. I have a fuse box there which might be a replacement. How far above the cut out plate would it be? You see I have some sort of rubberized black paint coating the whole engine bay. I'd have to start taking a wire wheel to the area. I'd like to know where to start.
Are the numbers running verticle or horizontal?
[ QUOTE ]
[/ QUOTE ]
