Miata Seat Install
jhorton3
I picked up a pair of Miata seats to install in Midgie. Does anyone have tips and tricks on how to get them installed?
roofman
Search the Triumph forum, lots of info. on installing in a TR6 that might help you.
v8mgbal
Hey Jim you can go to mrmikes and see detailed instructions on doing them or Tony's site the Autoist. I just got some fiero seats from the pull-a-part they look good in the car,good luck on the install.Alan
JPSmit
Not too long ago I seem to recall someone posting pictures of the rail mods - I remember a bolt with angled spacers
Jim_Gruber
I've got Miata Seats in Bugsy my '68 Sprite. Great upgrade and replacement for the old stock seats with crappy upholstery. You'll see my name mentioned on the post above. These seats are simple to install. You can reuse original inside front locating bolt with the seats. The other three mounting bolts will require new holes. Watch out for the brake line or is it fuel line on hte back Passenger Side when redrilling holes.
I used a piece of 1" square channel under the rear of the seats to raise them to level. Someone else used a piece of pipe cut at the proper angle to work as a mounting bolt adapter as the Miata floor is not totally flat like a Spridgets.
One of the neatest thing about Miata Seats is speakers in the headrests. Zipper is there but hidden well. I found a set of 6 x 9's in the rear deck and 4 headrest speakers a bit much for the Sony CD player. Had issues with blowing fuses at high power outputs after I added Bass Block Capacitors in the headrests. Caps were sucking up too much power. I disconnected speakers on Passenger Seat as 99.5% of the timeI drive by myself. It's sort of like driving with headphones on, sound is so much better.
Get the old seats out, read the post, and ask quesitons. Glad to help as I've been down this road already.
Magyar
Hey Jim, Please take lots of pictures and log any bits of helpful information or hints that you come across. I'm planning that task for next winter's project. Does your new Miata seats have the speakers in the headrest? If so, do you intend to hook them up?
Good luck on your project.
Magyar
Jim_Gruber
All Miata Seats come with speakers in the headrests. Zipper for access is really, really hidden. Hey seats are installed in Bugsy. Speakers are like driving with a headset on and really sound nice. I added a couple of Bass Blocker capacitors to keep the bass note from blowing the speakers and let the 6 x 9" provide bass. I'd recommend coming over from Columbus to do a trial fit / drive before you install. I did gain some additional seat / leg room with the roll bar as Miata Seats are thinner than Spridget seats. Not that I need Leg room at 5'6" but I still drive with seats as far back as I can get them.
Magyar
Thanks Jim, I am looking forward to a road trip to Dayton as soon as the weather breaks. Hopefully we can get together, and I'm also planning to stop by the Airforce museum, it's be awhile.
Another note for anybody looking for Miata seats or anyother part, I found a great web site for car parts, www.car-part.com. You list the year of interest, Make/Model, Part, location, sort by, and your zip. I found a great selection of Miata seats available all over the USA. Not sure at this point if they are really there, but I plan to pick up a pair in my travels within the next year for a next winter project.
Happy Hunting
jhorton3
jhorton3
Miata seats were installed this weekend. Passenger side easier than driver's side. I made the angle cut PVC adapters for the angled original Miata rails. Front PVC pieces are cut at a 20 degree angle on my bandsaw. I had the wife come out to test the placement of the seats on the floor before drilling and bolting. Glad I did as we got them where both of us can adjust for driving or riding.
We're very impressed by the improved ride quality with these seats over the originals. Granted they originals needed to be revamped but wife never liked the feel of the original style in good condition. In the Miata seats our behinds aren't sliding around all over the place, and they are more comfortable for us. We took a 40 mile round trip today which is something we haven't done for over 6 months. Very comfortable. Will be glad to get carpet and panels installed hopefully in the near future.
jlaird
WTG
Jim_Gruber
Jim,
I'd just be a little nervous using PVC adapters in getting the mounting bolts straight. Granted they are only spacers to get some angles corrected but I'd think about at least using a solid piece of oak better yet a piece of steel pipe like someone else did. I hesitated working with such small pieces with my bandsaw as I didn't want to get a new nickname "Les Digits".
My solution simply used a 1" piece of square tubing under the back of the seat. The tubing raises the seat back, makes the seat slides level, and changes the angle of the bolt so they are just about straight up and down. Some big bolts and multiple fender washers and you are set. The 1" tube also adds some rigidity to the floor and spreads the load.Pics are available if desired.
Morris Miata seat install kit Spridgets 27
bill_powell Miata Seat Install [Attn MIO] Spridgets 7
T TR4/4A Tr4a - 3 point seat belts with Miata seats Triumph 8
jhorton3 Replacecment Miata Seat Covers Spridgets 12
BobbyD Miata Seat Brackets..... a new approach Triumph 0
bash TR6 Adding Miata Seat Speakers to TR6 Triumph 2
G TR6 TR6 with Miata seat recover Triumph 21
A TR6 TR-6 need Miata seat adaptors Triumph 2
philman Wedge Miata Seat installed in a TR7V8 Triumph 10
Brosky Miata Seat Up-date -- Progress!! Triumph 9
Brosky Miata Seat Up-date Triumph 0
Brosky Miata seat prep continues Triumph 48
BobbyD Miata Seat Brackets...... Uncle Jack's! Triumph 0
BobbyD Miata Seat Site Up-date Completed..... Triumph 8
bill_powell Miata Seat Headrest Speaker Wiring Spridgets 6
T Anyone have the Miata seat diagrams from Mark's Ga Triumph 4
Paulus Seat adapter plates for Miata seats. Triumph 10
milemarker60 Miata Seat Belt Receiver Question Triumph 4
G Miata seat mod. Spridgets 5
N TR6 Need drawings for Miata seat mounts in a TR6 Triumph 4
mrv8q Miata Seat conversion Triumph 17
roofman Miata seat conversion Triumph 18
hondo402000 TR6 Miata seat for TR6 Triumph 13
Cain TR6 Miata Seat Covers for TR6 Triumph 9
AngliaGT 1997 Miata - Anyone Have a Picture on How to Mount the Front License Plate Bracket? Other Cars 12
waltesefalcon Miata Water Pump and Timing Belt Other Cars 3
mezy mazda MX5 / Miata gear stick relocation Other Cars 2
waltesefalcon Miata windows Other Cars 4
waltesefalcon NA Miata gauges Other Cars 16
waltesefalcon The Miata rides again Other Cars 11
R TR6 Mazda Miata ride, everything else TR6 Triumph 13
AngliaGT "Nice Miata!" Other Cars 13
jfarris TR2/3/3A Venture into the "dark side," Miata seats in a TR3 Triumph 9
Magyar For Sale Miata Seats, Tan Leather Spridgets Classified 2
F TR6 miata seats Triumph 12
AngliaGT Miata - ALMOST Made it Home Other Cars 7
TRMark TR4/4A Miata Battery Triumph 6
J For Sale 1976 Sptifire with 1.8L Miata engine/5-speed [running like a boss!] Triumph Classifieds 0
Raymond MGB Miata seats? MG 1
JPSmit Miata Coupe Other Cars 3
C A better sound for a Miata? Other Cars 0
R TR2/3/3A Miata Engine and transmission Triumph 12
John_Mc TR6 Floor pan to frame mount question/Miata seats Triumph 2
M MGB MX5/Miata seats for MGBGT MG 2
T TR4/4A Making Miata seats in a TR4a look more "right" Triumph 4
T TR2/3/3A Miata seats installed in my TR3A Triumph 14
T TR2/3/3A Will Miata seats fit in a TR3A? Triumph 7
DornTRoriginal Miata 1997 MX-5 Shock Absorber repalcement assistance Other Cars 2
G MGB Miata seats MG 4
NutmegCT MGA MGA/Miata MG 12
