CCURTISS
I am having a loud shifter rattle on our TF. I pulled the retaining clip, cap and spring then I cleaned it up and added new grease, put it back together but it still rattles.
Here are my two questions.
I pulled up gently on the shifter once the retaining rings are removed but the shifter would not come out easily. How do I get the shifter to release from the ball insert at the base of the shifter linkage?
The second question is what could be causing the rattle, I looked in the Moss catalog and I do can not see anything other then the spring and ball at the bottom, no bushing that I can see.
Thanks,
Thanks,
