MGB MGB Tires The Good, the Bad, and thhe Ugly
Radford
I'm looking for advice as to what tires will work best on my stock 1975 B rims. What's the "biggest" tire I can run without modifications?
jaybird
At our car show Sunday, I checked the tires on 25 other Bs. The biggest I saw were 185's, although most were 175's. I'm going with 175/70/14's on mine.
Steve_S
185/70 is the largest that will fit with a reasonable amount of stiffness but will still have sidewall flex. Any larger than 185 and you will suffer very poor handling unless you instal a wider rim. 175/70 would be the best choice for handling and ride, 165 would of course fit quite nicely.
Jack_Long
Good luck finding 165-14's, the original size for most B's. They are virtually un-findable unless you want to go to Coker and pay $150+ each for Michelin XZX replicas. 185/70 is the appropriate upgrade size; the rule of thumb is 2 size widths for every 10% lower in profile. 175/70 is a tiny bit smaller in diameter and might make your speedometer read a little bit high - although probably well within the normal range of error for 30 year old English cars!
Radford
Radford
Thanks for the imput so far. I have 175's on the care now, but knowing that 185's work gives me a lot more options.
Any brand or range I should stay away from?
Jack_Long
My B came with 185/70 Cooper's on the front and 185/70 Michelin MX's on the back. Amazingly for tires that are supposed to be the same size, the Michelins look huge - both in diameter and in width. While mine don't rub, it is really close on the driver's side rear wheel opening lip. I'd probably be careful with the Michelins on a steel wheel car and avoid them altogether on a wire wheel car.
Steve_S
I noticed the same, Jack. I had BF Goodrich 185/70 on a set of 5" rims and they looked huge. Put a new set of Sumitoyo HTR200 on the same wheels and they look a full size smaller. I suppose that means if you're going to 185's on a 4.5" rim, the Sumitoyo may be a good choice. Still going to be flexy on such a narrow rim but better than some other tires.
jaybird
[ QUOTE ]
[/ QUOTE ]
Speedometers WORK???
Jim 67B
I have had a tire lose it's bead and now are looking at getting at least two new tires maybe four. What I have found is that 175/75R14 is very close to the original size both in overall diameter and width. Cooper still has a tire in that size. Then I found that Nankang still makes the 165R14 tire. It is their model 802. If you can find a dealer that carries them they are about $41.00 each. Since I have wire wheels, I am looking for a tire closer to the original width. If you have the Rostyle wheels I would go with the 185/70SR14 tire. They will fit the rim nicely and are very close to the original overall diameter.
703MGB
I was running 185/70 14 up to yesterday and the fit on the rostyle was perfect. So 185 are ok.
Now I am running 195/65 15.
Radford
Radford
[ QUOTE ]
[/ QUOTE ]
New rims? What'd ya get?
Nunyas
I have 185/70 14's on Rostyle rims, but I forget which brand. This past weekend while adjusting the rear brakes and replacing rebound straps I noticed that the inside wall of the wheel well (the side behind the tire) has some minor rubbing (took off some under coating but paint still in tact). While sitting level and even while jacked up the clearances look fine, but I guess under full load of driving the body roll and axle shift are just enough to rub a little. I think I also noticed that my rear suspension bushings were a bit worn...
I've plans to rebuild the front suspension. Looks like I need to include the rear while I'm at it.
703MGB
Never had any rubbing with my old 185/70 14's but all my suspension bushings are new and are Polyurethane. Plus leaf springs, shocks....and do on are new.
Radford
Radford
[ QUOTE ]
[/ QUOTE ]
I was thinking about Pirelli P400's. Would I be wasting my money?
/ubbthreads/images/graemlins/thirsty.gif
Keoke
Jack,check out British Wire Wheel they stock 165 X 14 Tires at under $50.00, Hendrix on the east coast probably does too.FWIW---Keoke
Nunyas
mine's on both driver and passenger wheel wells. There appears to have been more rubbing on the driver's side though. Possibly because of there normally being only the driver and right hand turns being sharper?
usasma
FWIW - I've got Dunlop 185/70's on my 74½ and don't have any problem with rubbing.
P MGB MGB tires MG 11
J MGB Are 175 tires the widest that will fit onto a MGB?? MG 3
Hoosier MGB Nearly new Tires plus wheels for MGB MG 8
G MGB MGB tires MG 3
PAUL161 MGB MGB Wire Wheels & Tires MG 7
CJ Burton MGB-GT Bolts for INERTIA STARTER on 1966 MGB GT MG 7
M MGB Ground polarity '67 MGB MG 2
M For Sale 1978 MGB MG Classifieds 0
Carlbanan56 MGB MGB oil consumption MG 5
A Wanted 1970 MGB - Emissions Parts MG Classifieds 3
C MGB Re strapping a MGB seat bottom MG 2
Simmo MGB Re Engined MGB MG 4
Carlbanan56 MGB MGB rear break rebuild MG 6
C Wanted Early MGB soft top and/or tonneaus, condition not very important MG Classifieds 0
Carlbanan56 MGB Mgb turn signals MG 17
J MGB 1970 MGB Steering Lubrication MG 1
C Wanted Wanted: 1977 to 1980 MGB Dashboard MG Classifieds 0
L SOLD!! For Sale MGB Hardtop MG Classifieds 3
EvansClassicCars For Sale 1980 MGB for sale MG Classifieds 0
J MGB Tire pressure for 1980 MGB MG 14
5 Wanted Wanted 1966 mgb banjo type axle rear hub MG Classifieds 0
I MGB Purchase of 1972 MGB Roadster MG 3
C MGB-GT MGB-GT Front Ride Height MG 0
J MGB Advice for new MGB owner? MG 16
D Wanted Wanted: Chicklet Headrests for MGB/C! MG Classifieds 0
Editor_Reid MGB Anders Clausager's "MGB" book MG 4
J MGB 1966 MGB won't start MG 1
Erica General MG Oil Drain Valve -- mine is an MGB, but they have others MG 3
TunaJ Will MGB Upper Seat Runners work with Midget seat rails? Spridgets 1
Erica MGB Carburetion and MGB fuel economy. MG 0
wkilleffer MGB MGB clutch slave bleed driving me nuts MG 38
R MGB side chrome installation MG 4
C MGB MGB MG 5
3798j Off Topic MGB at the Drive in Bank MG 1
wkilleffer MGB 1974 MGB clutch master cylinder questions MG 1
Rut MGB 62-67 upper MGB steering shaft MG 3
VeeCee MGB 1974 MGB Roof Installation MG 0
J MGB Just bought a 1966 MGB MG 50
T MGB MGB hoses MG 6
AngliaGT ANOTHER TR6,& an MGB Spotted 0
G MGB Sorry from the Newbie...Clutch gone on 78 MGB MG 17
Briancole702 MGB-GT 71 Mgb gt no gas in float bowls MG 1
Ranger68 Wanted 1969 MGB Sun Visor Wanted MG Classifieds 0
R MGB MGB Roadster Door Panel Speakers MG 9
DrEntropy MGB Good video on the MGB MG 0
adcronin For Sale MGB Turn Signal (lights, horn, indicator) Switch, New for 62-67, also Sprite MK 3 & 4, MIDGET MK 2-3 thru 67 MG Classifieds 0
J Wanted 1969 MGB Roadster sun visor clip MG Classifieds 4
JohnGone MGB 1980 MGB Spark Plug recommendations MG 6
R MGB 1972 MGB Defroster Hose MG 2
T For Sale MGB Black Label Overdrive For Sale Or Trade For New RB Parts MG Classifieds 2
