MGB MGB Tire and Wheel Sizes
glemon
I have an MGB and an club autocross coming up and had a wickedly delicious thought, the car came to me with rather wimpy Goodyear 165/70-14 rubber. The cars has bolt on wheels I have some panasport type 15 X 7" wheels with 205/65s on them ready to go for another car that is far from being ready.
I know a "C" uses 15" wheels, is the bolt pattern the same for a B as a Triumph? the TR wheels have a 4 X 4.5" bolt pattern, I think a B does too but not sure.
And will the tires fit a stock B?
Steve_S
With poly bushings and a well aligned body / suspension, it may fit. On most MGBs you would have rubbing issues in the rear but some people are lucky in this regard. I run 15x5.5" wheels with 195/60R15 tires on my '65 B with no problems. Good luck!
WA1KWA
What rule set are you running under? Been a few years for me, but, under SCCA Solo stock class rules you will only be allowed the stock 14" size. Anything more & you're out of stock class. You can squeeze a 195/60 x 14 on there, the rears should JUST clear the quater panels. That's what I used when I ran my B.
Colin
glemon
glemon
Colin--Just our local club, no SCCA rules, run whatever want, classes are based on engine size, then we breake those up into stock and modified.
I realize the size is prbably too big and not ideal, but I may put them on to see if they fit, I have a later bumper B with the raised ride height, which I assume may give a little more room for wheels.
This is not a real serious effort, I just happen to have the new wheel tire combo and thought it might be fun to raise a few eyebrows we started doing club autocrosses 5 years ago or so, and some guys have gotten pretty serious about it.
swift6
If the rest of your car is still stock, pump up those wimpy tires to something like 40psi and go for it. Those bigger tires and wheels will only slow you down.
WA1KWA
Good advice from Shawn. Remember to keep the fronts 4 psi more than the rears. Get a big piece of that sidewalk chalk they sell for kids & use it to mark your sidewalls onto the treads. That way you can see if you are cornering on your sidewalls & adjust the pressure accordingly. Unless you have a supply of air wher you are running, think like you dress when you go out on a spring or fall day: you can always take off, but you can't put on what you don't have. Same with your tires. Pump them up high; if there is no air there, you won't be able to add any, you can always bleed off, but do it spairingly.
Most important: Have Fun!
Colin
Steve_S
That's the first time I've heard of someone running more air in the front than in the rear on an MGB. With more weight in the rear, the typical setup is to run 2 PSI more in the rear! Of course everyone's setup is different after 40 years of fiddling and driving style will make even more of a difference.
FWIW, I run 195/60R14 on one of my Bs and there is ample clearance. The ride height is unchanged from stock but with those little tires is could stand to come down at least 1/2", which would reduce clearance slightly.
glemon
glemon
I am certainly not an expert on MGB handling, but in general I run the fronts higher than the rears in solid axle front engine british cars including Sprites, TRs, etc.
Although I don't have empirical data to back it up (haven't tested it) the theory is: 1) Front end is heavier, so needs more pressure 2) Reduces understeer 3) the rear ends tend to be stiff and have limited travel, so a little more cushion at the rear than the front to prevent rear end bounce and slide on rough surfaces.
CurtisJ
The original post seemed to ask about putting aftermarket (oversize) wheels from a TR6 onto an MGB.
The two suspensions were designed to accept wheels with different "offset" measurements. Offset is the dimension from the mounting surface (hub) to the plane that goes through the center of the wheel perpendicular to its axis. For oversize MGB wheels, offset of 22mm (or more) is normally used. For oversize Triumph TR6 wheels, offset of 6mm or less is normally used. In other words, even if the tires would fit, the TR6 wheels would mount them in the wrong plane.
For what it's worth, there are a few MGB V8 and V6 conversions driving around on 15 x 7 tires. It can be made to work quite well...
This MGB is running on 15x7 wheels and 225/50 tires:
glemon
glemon
Thanks Curtis, best answer yet, didn't know the offset was different, my 15 X 7s are zero offset.
P.S. the B looks nice with those wheels.
Steve_S
TR6 wheels will fit on MGB but as Curtis said the offset is different. I've seen a B driving around on them with no issues but I would be surprised if the steering didn't suffer a bit from the change in geometry. The other option is to remove the rims from the TR^ wheels and have them re-centered. New rims would most likely have to be used. Many older wheel shops can perform this service.
Regarding tire pressures, remember there is more to it than simple weight balance. The front tires are steering the car and the rears are subject to power being transmitted through them to propel the car forward. Every setup is a bit different, but typically more pressure is used in the rear than in the front.
glemon
glemon
Well, I was just thinking of popping them on for our club autocross since they were just sitting there with nothing to do. I know they were really not the ideal size, sounds like the "might work" but the autocross was today, and my brother offered the use of his 911 so I took that route.
It is just a very hard life I lead....
J MGB Tire pressure for 1980 MGB MG 14
B MGB 78 MGB Spare Tire trunk lockdown thingie MG 13
htchevyii MGB need tire size recommendations for 77 MGB MG 6
R6MGS MGB Biggest 15 inch tire for 80 MGB MG 9
bcliff MGB MGB tire size MG 2
RickB MGB Quick tire size question - MGB MG 10
kyreb1862 MGB MGB Tire Size MG 13
703MGB MGB Tire size for MGB roadster 73 MG 12
CJ Burton MGB-GT Bolts for INERTIA STARTER on 1966 MGB GT MG 8
M MGB Ground polarity '67 MGB MG 2
M For Sale 1978 MGB MG Classifieds 0
Carlbanan56 MGB MGB oil consumption MG 5
A Wanted 1970 MGB - Emissions Parts MG Classifieds 3
C MGB Re strapping a MGB seat bottom MG 2
Simmo MGB Re Engined MGB MG 4
Carlbanan56 MGB MGB rear break rebuild MG 6
C Wanted Early MGB soft top and/or tonneaus, condition not very important MG Classifieds 0
Carlbanan56 MGB Mgb turn signals MG 17
J MGB 1970 MGB Steering Lubrication MG 1
C Wanted Wanted: 1977 to 1980 MGB Dashboard MG Classifieds 0
L SOLD!! For Sale MGB Hardtop MG Classifieds 3
EvansClassicCars For Sale 1980 MGB for sale MG Classifieds 0
5 Wanted Wanted 1966 mgb banjo type axle rear hub MG Classifieds 0
I MGB Purchase of 1972 MGB Roadster MG 3
C MGB-GT MGB-GT Front Ride Height MG 0
J MGB Advice for new MGB owner? MG 16
D Wanted Wanted: Chicklet Headrests for MGB/C! MG Classifieds 0
Editor_Reid MGB Anders Clausager's "MGB" book MG 4
J MGB 1966 MGB won't start MG 1
Erica General MG Oil Drain Valve -- mine is an MGB, but they have others MG 3
TunaJ Will MGB Upper Seat Runners work with Midget seat rails? Spridgets 1
Erica MGB Carburetion and MGB fuel economy. MG 0
wkilleffer MGB MGB clutch slave bleed driving me nuts MG 38
R MGB side chrome installation MG 4
C MGB MGB MG 5
3798j Off Topic MGB at the Drive in Bank MG 1
wkilleffer MGB 1974 MGB clutch master cylinder questions MG 1
Rut MGB 62-67 upper MGB steering shaft MG 3
VeeCee MGB 1974 MGB Roof Installation MG 0
J MGB Just bought a 1966 MGB MG 50
T MGB MGB hoses MG 6
AngliaGT ANOTHER TR6,& an MGB Spotted 0
G MGB Sorry from the Newbie...Clutch gone on 78 MGB MG 17
Briancole702 MGB-GT 71 Mgb gt no gas in float bowls MG 1
Ranger68 Wanted 1969 MGB Sun Visor Wanted MG Classifieds 0
R MGB MGB Roadster Door Panel Speakers MG 9
DrEntropy MGB Good video on the MGB MG 0
adcronin For Sale MGB Turn Signal (lights, horn, indicator) Switch, New for 62-67, also Sprite MK 3 & 4, MIDGET MK 2-3 thru 67 MG Classifieds 0
J Wanted 1969 MGB Roadster sun visor clip MG Classifieds 4
JohnGone MGB 1980 MGB Spark Plug recommendations MG 6
