MGB MGB Motor Rebuild
Lynn Kirkpatrick
I have 2 questions:
A)Does anyone know the allowable endplay in the distributor drive gear? I read it someplace, but I can't find it again and I've gotten behind in my photographic memory classes so I don't remember the number. I don't think that I dreamed it. It would affect timing, I think.
2) I also read that there is a difference in the flingers on the crankshaft, inside the timing cover. I had to replace the cover and crank pulley. Fortunately they are compatible , the timing mark on both moved to the top, so their relationship has not changed. Now I'll check timing from above. But do I need a different flinger?
Lynn
A) endplay shouldn't affect timing to a noticeable degree unless it's reallllllly screwed up. I'll bet the figure is in the Bentley manual though.
2) /ubbthreads/images/graemlins/confused.gif
Lynn, I presume you are referring to the oil slinger? All my books show the same slinger ring for all "B" engines. But, I'm not really a "B" guy. Maybe Tony can jump in with some of his sage advice on this one.
Jeff
[ QUOTE ]
I have 2 questions:
[/ QUOTE ]
I'm with Kenny, I've never heard of dizzy endplay causing an issue with an MGB timing. The shaft bushings are usually the culprit of dodgy/wobbly timing.
