Manifold-tailpipe v clamp
S
slacsteve
Is there supposed to be a gasket "asbestos" in there. I can't get mine to seal the exhaust.
Smear a bit of muffler sealer on the connection. Comes in a tube and is white.
Made for sealing leaking mufflers, tail pipes etc.
if it is the earlier style that is metal on metal with the horizontal clamp that just wedges the manifold to the pipe I used muffler tape around the joint before putting the clamp on & it worked great, no leaks.
A stock '66 uses no gasket, just metal on metal. Put it together carefully and be sure to use the bracket that attaches to the transmission (to keep the pipe from swinging and breaking off of the manifold) and you will have many miles of "quiet" driving.
Bill
OK I'll give it a try. I did succeed a couple of years ago but for the past year it loosens up and falls down. It is hard to feel or see if you have the V symmetrically captured the flared cast maniforld and the sheet metal tube/pipe.
948 and 1098 clamps are different so be sure you have the right one. Everything
has to be up to snuff or they can be a real pain. There is a reason they changed that system!!
Kurt.
