I have been running a Mallory Unilite ignition system in my 100 coupled to a ceramic ballast resistor as recommended and an MSD coil for 15 or so years with no issues. The system was wired as per Mallory's instructions shown on the attached "Unilite--Original Wiring" file. The purpose of the ceramic ballast resistor is to reduce voltage to the ignition module from 12 to about 6 so as to protect it from overcurrent.
Recently I decided to replace some older wires and connectors with new and in the course of planning the reactivation of the ignition system I found a number of posts in different online sites--mostly for muscle car and other large V-8 applications--recommending the addition of a new wire from the ignition switch to the positive side of the coil. The purpose of it would be to temporarily increase voltage during starting.
I've never had any difficulty with starting and the car usually fires off almost immediately, Nevertheless I thought I'd give things a try and so yesterday I added the new wire from the start button to the coil positive. as shown in red on the second attachment "Unilite Revised". On pushing the start button the car started instantly, but died as soon as I released the button. This repeated several times and only after removing the new wire from the start button to the coil would the car run after starting.
I'm really okay taking "no" for an answer and have eliminated the problem simply by disconnecting the new lead to the coil positive, but I would like to understand why this is happening--It's as if the coil was being de-energized or somehow grounded out. The start button also energizes the built-in solenoid for the aftermarket gear reduction starter, but I don't see any way that could be the culprit.
Thoughts please?
Thoughts please?
