Lucas coil question
Lin
I am testing an old coil. On the 3 ohm coil, what should the secondary side of the coil read when hooked to a multimeter (20K setting)?
Thanks.
Lin
Keoke
Lin :
W hat color is the insulator ?
Keoke
That is probably the sport coil and it is good to go--Put it in N see how car runs OK . I no longer have the tests I made years ago , sorry ole Pal.
spinaway
Hi Lin
Lucas SA12 Sports Coils have a secondary winding resistance of approx 7.5 Kohms. These were the most common sports coils of the day, maroon-red painted top insulator. They have an approx 3-ohm primary coil.
The earlier HS12 sports coil also seems to be about 6-Kohm to 8-Kohm for secondary winding.
I would say if you are seeing anything from 6-Kohm to 10-Kohm on the secondary then its worth trying out.
Regards
Lin
Lin
I am getting a 6.55 ohm reading. So, I guess I have a good coil. Silver case, black top. Thank you!
Lin
Keoke
Well :
I was ah guessin U was still on the 20 K scale--LOL
T Lucas Sport coil question Triumph 21
M Replacement of Lucas HA12 with Lucas SA12 Coil Austin Healey 6
S Intermotor or Lucas Sport Coil ? Austin Healey 14
Lin Chrome Lucas Sport Coil? Austin Healey 9
P Lucas Sport Coil Austin Healey 2
S Lucas Sport ignition coil Triumph 29
drambuie Exploding lucas sport coil Austin Healey 33
Jim_Newman Lucas Sport coil Austin Healey 2
bighealeysource Pertronix coil verus standard Lucas coil Austin Healey 3
W NOS Lucas Sports coil on eBay Spridgets 3
G GM Module in Lucas box [ was PICKUP COIL + wire?] Spridgets 5
angelfj1 TR2/3/3A Lucas Ignition Coil for TR3A Triumph 1
lbc_newbie Lucas electronic distributor - do I need a coil? Spridgets 1
kyreb1862 Hooking Up A Lucas Sport Coil MG 6
Brosky Who was looking for Lucas coil stickers? Triumph 0
kyreb1862 MGB MGB Lucas Sport Coil MG 1
kyreb1862 Lucas Sport Coil MG 20
Brosky Is the Lucas Sport coil worth the effort? Triumph 4
S TR2/3/3A tr3 Lucas coil Triumph 6
DerekJ Lucas Sport Coil vs Normal Austin Healey 2
jmayled Lucas Sport Coil Installation Triumph 16
S Correct hookup for Pertronix and Lucas Coil? MG 3
D Lucas Sport coil / Pertronix ignitor MG 9
6 Lucas Hi Output coil Jaguar 10
J For Sale Lucas 75150A Wiper Motor Other British Classifieds 0
L TRW-Lucas Brand Master Cylinders Austin Healey 2
R TR6 Lucas Starter 2M100 - Extra Part? Triumph 2
angelfj1 TR5/TR250 TR250 - Lucas 4ST Starting Solenoid-Mounting Location/Details Triumph 2
MGTF1250Dave T-Series Lucas Generator MG 1
T Lucas Flasher Unit Austin Healey 5
D Lucas Low-Tension Leads Austin Healey 1
Popeye General TR Connecting to Lucas switch grub screws? Triumph 5
Rob Glasgow Wanted Headlight Lucas Austin Healey Classifieds 4
H Lucas Starter Model for 3000 Mark II, BT7 Austin Healey 3
B Wanted Lucas wing mirror Other British Classifieds 1
B TR6 Swapped Lucas to GM alternator Triumph 9
AngliaGT For Sale Lucas Headlight - used MG Classifieds 0
J TR2/3/3A Early Lucas Ignition Switch Triumph 4
M Looking for Lucas parts catalogue British Motor Corp 13
AUSMHLY Lucas Generator C42 End Caps Austin Healey 3
B Delayed charging Lucas alternator Triumph 1
S Stag Lucas 18ACR alternator conversion Triumph 5
red57 Lucas 1748 horns Austin Healey 19
B TR2/3/3A Lucas, SU, and the rest Triumph 3
K TR2/3/3A Who owns the "Lucas " brand name? Triumph 7
K TR2/3/3A Do Lucas distributor points still have the" Lucas logo" on them.... Triumph 4
K TR2/3/3A What vehicle is this Lucas voltage stabilizer from? Triumph 8
F How do I get rid of "Lucas"? FORUM Navigation Questions 2
T Which Lucas dynamo does a BJ7 have? A C45?? Austin Healey 6
F T-Series Lucas m133 headlamp? MG 2
