LIN I always used Coppa Slip worked greatThanks Dave and Mike,
Mike, once you reminded me about the Annapolis Rigging, I remembered that you had recommended them to me years ago. I went to the garage and dug into my tape/adhesive drawer and sure enough I found the Teflon tape and as an extra bonus there is enough of it for this job. Thanks for the memories…
Dave, I agree with your comment about grease attracting grit, and I am in Florida where there is plenty of sand and grit!
Lin
Thank you both. I know that WD40 is not a lubricant, but I was under the impression that 1959 leaf spring technology did not use any lubricant. And I’m told that grease will just attract dirt. The dry graphite sounds like a good idea; has anyone used it? I plan to wire brush the leaf springs thoroughly, and perhaps spray the sides and shackles if the springs with the graphite.
