G
Have any of you out there that have installed new U-joints on your TR6 figured out a way to get to the Alemite on the outboard rear axle joint? That little sucker is totally hidden within the confines of the aluminum swing arm. I found a cool little gizmo that afixes to the end of my grease gun to get to the other joints, a straight tube with a nylon collar that allows you to cover the tip of the Alemite and pressure-fill the grease fitting but I need something like a 90 degree short right angle to get to that hidden one. Short of pulling the hub, I see no way to get to this little bugger. And all the replacement joints I have found are all lube-type. A lot of little words for a potentially big problem, like I need another problem....
Bill
Bill
