Lube Help
DNK
Need a proper lube product for fuel rubber hose to a barbed hose fitting that is tight.
Thanks
Dishwashing detergent!
Assuming you need something to help the hose slip onto the fitting.
Tom
DOH!, thanks Tom.
Just didn't want to effect the fitting application
...ie... leakage
Is it OK to heat up the hose with a heat gun to facilitate installation?
better to use very hot water.The heat gun can mess up the hose
Don't know if I can get my car in the kitchen
I will have to measure the door openings
Take the windscreen off and turn the car on it's side. It'll fit. :cooler:
Uh Oh... Any one know how to get tire marks off the door jam before SWMBO gets home.?
Hmmmm... How long do you let it soak
Maybe my fitting is to big
I remember one year on a lead-up to Family Camp for our Church, we put my 1949 Willys street rod in the foyer.
Had folks waiting around afterwards to see how we got it out. I told them we removed the roof tiles and lowered it in by ropes.
Removed the mirrors, both sides, used motorcycle straps to squeeze the tailpipes together, removed the doors to the Church, and rolled it out with less than 1/2" to spare.
If I can do it, YOU can do it!
Dave
Yea, bad advice 5/16 inch hose and 6AN fitting.
Told the guy I thought 6AN was 3/8's
Every time I get frickin excited to work on the car I go out and none of my plans work
Sure goes to show you about keeping things stock
Yep, it doesn't matter hbow many upgrades you make...it doesn't perform any better in the garage.
It really is getting to me.
Very frustrated
