Lowering front and rear
rjc157
Might have been posted before i'm looking to lower the front and rear end because the car justs sits to high i'm running 195 65 r15 its a bj8 ,any thoughts or pics
Accepted practice for the front is to use spacers between the lower control arms and spring pan; may require the use of altered bump stops (upper & lower) too. There are kits commercially available.
Similarly, a spacer block between the rear axle perches and springs would acheive a reduced ride height.
I'm already dragging on everything, so I've neither needed nor tried either method.
I lowered my BJ8 using the spacer method:
Before:
New bolts with washers for spacing:
Bolts in place with 6 washers all around:
New ride height = happy:
